Muffled Rattling in rear BigBend Passenger side panel
Summit
East of Nashville
2022 Bronco BIGBEND & 2024 (Full Size) Bronco BIGBEND
There is some kind of fluttering/rattling noise in rear passenger side panel.
I thought it might be the wheel well skirt fluttering at highway speeds but it is tight.
Anyone ever have that panel off on passenger side rear?
What's in there?
Chiefthepup
Colt
Washington
It might be worth checking your spare tire. I had a similar noise happening and it was the tire offset just enough to rub against the metal at every minor bump and turn.
KidWiff
CT
2023 Bronco Sport Heritage
I think I read a similar situation and it turned out to be the “cab vent” that lets air escape when you close your doors, back hatch, etc…. The flap that (I’m guessing) helps to keep critters out, starts vibrating at certain speeds. Could be wrong, but I seem to recall that. (My BS does it occasionally as well)
Bluesteelworx
Jeff
Quakertown, pa
Bronco sport, GMC Sierra
What's in there?
No, but I am experiencing exhaust fumes coming into the cab. Had it to dealer three times and they all say they can't detect it. Nor have they ever heard of the problem before. I still smell exhaust fumes at every stop when the heater or ac is on. I have seen other forums where customers have reported the same thing.
Summit
Summit
East of Nashville
Sorry to hear this. I would rather have a rattle over fumes but I would stay on it and see if you can get it resolved.
What's in there?
Hi there, Kevin! If you'd like to, go ahead and send us a private message with your VIN and dealer info and I’ll look into this rattling concern. Thanks!
Good morning! This exhaust fumes concern isn't something we want you experiencing. Could you privately message us with your VIN and dealer info to begin assistance? Thanks!
21Broncosaurus
Ish
SoCal
21 Bronco Sport
I had the same problem with Ford Tech saying the exact same thing. It’s like these guys check the vehicle for a few minutes and move on to the next. I too need to take my vehicle back to have it inspected once again. Other members have reported a crack in the catalytic converter was the cause so maybe check there.
21Broncosaurus
Ish
SoCal
21 Bronco Sport
What's in there?
There’s a few threads about noises in the cargo area. Just search for “flapping”
cario65
Chris
Northern Virginia
2023 Bronco Sport (ordered 8/11/22)
Have the same noise. It’s the louvers on the rear vents. If you ever seen a vehicle with its rear sheet metal off you can see them.
I discovered that the noise is present when the recirculate button is on. Air pressure while driving is lifting the louvers and settling back down making the noises. If I turn off recirc, air flows out the vents through the inside of car and are held open by this airflow making noise go away.
Just my deduction as I can’t actually see the vents in action. My ears are telling me this is what is happening.
You can easily recreate the sound with the car sitting still. Make sure all the windows are up, get out of the car, then push the driver's door closed from an inch or so. Don't slam it, just close it to within an inch or so, then smartly push it shut from there. Doing this will briefly increase air pressure in the cabin forcing the vents open. You'll hear the vents close a half-second after you shut the door.
Hello, Chris. Are you still experiencing this rattling concern? If so, I would like to look into it on my end. Please send over a private message with your VIN and the name/location of your local Ford dealer.
