MAX Air Conditioning
Jasper Weed
Louisville
2024 Bronco Sport Badlands
***BUMP***BUMP***BUMP***​
I've had a Badlands for about 4 months now and I am having almost the same issue. I was wondering if anyone has had anything for a fix instead of the cabin filter.
I have discovered that it has to be at least 70' out before the air will work right. Even then it takes a bit for it to ramp up, I've never had a vehicle do this. If it's below 70' I can turn the thermostat down to 65'-64' before the hot air will just barely start cooling down. I have to put it on Max at 60' just to get some cool air going. Not cold, cool. But this issue only happens about 75% of the time. for instance. It was 65' the other day we went on a family ride and about 4 miles into it we were freezing. By the time we got to our destination about a 40 mile ride, I had the thermostat set on 74' and we were still pretty chilly. Also, does anyone else's blower motor sound like a prop planes engine when it is on the top 3 settings. It sounds like my dash is about to take off.
On different Ford forums I have read anything from low on freon, compressor, expansion valve, cabin filter among other things. And I guess I will have to end up at another dealer because my usual one has the " we can't get it to duplicate the issue when we diagnose it" syndrome disease. I have been having transmission trouble and a couple of other things. When the tell me it's ready and I pick it up that is what is on the ticket. Then I get the service advisor or manager ang show them before I leave and they just say, "oh, well we couldn't get it to do that".
One last question, does the Ford Rep still get on here any? I have seen them reply in old threads but nothing that I have looked at of lately.
Thanks
Some answers:
1. Regarding “blower motor sound like a prop planes engine when it is on the top 3 settings”
Have a look directly under the passenger side (from the floor, below the glove box look up behind the glove box) - do you see a panel or are you looking directly up at the bottom of the blower motor, passenger side fuse box, etc?
You could be missing the Fuse panel cover, interior, passenger side:
Instrument Panel Cover Passenger Side
M1PZ-78046A25-AA
Dash Panel Insulator, Part #: 78046A25
While there, go ahead and lower the glove box completely and check the cabin air filter - make sure is clean and not clogged up
2. The Ford Rep no longer monitors this Forum
Me3
Paul
Northern Nevada
RAV4
The AC condenser had to be replaced at 15k miles on my ‘22 1.5l. Covered by the 3 year warranty. It only blew outside air temperature air. The highest fan setting was loud, not excessively so.
Jasper Weed
Louisville
Some answers:
M1PZ-78046A25-AA
I added the cover after I first got it. I took it off thinking that maybe that was what was causing it. I just put a new cabin filter in. I took it out thinking that maybe it was the problem. But neither one was the issue. I'm taking it into the dealership today since the A/C has been blowing hot air off and on lately. Some days it will run you out and others it just blows hot air.
Don't know why the pic doesn't load; it's from this site! I copied a photo from the owner's manual instead.
I see the pic.
I live in muggy Florida. Our A/C blows out frosty cold air when the MAX button is pressed. It will cool the interior in less than a minute.
