Loose baffle in muffler at 40k
Summers22
Jon
Well just turned 40K and cold start yesterday had a loud rattle from the muffler. Pushing on the muffler driver side upward and the rattle nearly goes away. No loose heat shields. I have seen several posts on Google about this. Reached out to service advisor and they said get ahold of my salesman for a possible free diagnosis. I already know it wont be taken care of. So my options are another oem muffler at almost $400, a Magnaflow direct fit for $120 or a mallet and pound in that area to possibly crimp the loose baffle. Never had an OEM muffler fail.
Summers22
Summers22
Jon
Thanks but Im in Kansas. What did you replace it with? Google shows quit a bit of failed mufflers, even on the full-size Bronco.
Summers22
Summers22
Jon
Any suggestions for replacement besides OEM? I'm considering the Flowmaster FX, Magnaflow or MRT axle back. Just dont want it very noticeable in the cabin.
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
I got the MRT which is nice has a low grumble. Although mine and another member here both experienced the same issue with the flanged end that is supposed to fit over your factory pipe and clamp down did not slip over the factory pipe. The supplied clamp didnt even fit over the flange either. I made it work. And will probably weld it at some point
BLUEOVALRACER
Ohio
Magnaflow sells a direct fit Muffler for $120.00 if so I would go that route?.
Summers22
Summers22
Jon
BLUEOVALRACER
Ohio
Yes, I like that one, but I mispoke, its actually a Flowmaster FX. It'll have to be welded or possibly clamped, then a couple turn down tips added. That appears to be the most affordable option.
https://www.flowmastermufflers.com/products/exhaust/mufflers/flowfx_mufflers/parts/72206
Ford Bronco Sport Loose baffle in muffler at 40k 1000024183
Yeah that would be Your best bet at $120.00 IIRC the Flowmaster FX Cat Back is over $500.00 and doesn't give you much more besides the clamps and tail pipe tips. I had that on the 2023 BS BB I had at idle it sounded good but had to much drone IMO when driving it.I ended up taking it off returned it and put the stock muffler back on it.
Stircrazy
BC, Canada
were you recently on gravel roads? I find I get the same thing, had it checked out by ford and they found a bunch of gravel inbetween the heat shield and the muffler and it would make a rattle that soundsed like somthing was broken in the muffler. I find it clears its self eventualy, but that might be somthing to check for, unless you really really want that new muffler :wink:
Summers22
Summers22
Jon
No gravel roads and no, I want the quiet stock exhaust.
Chiefthepup
Colt
Washington
Yep me too. Been intermittent for a few months. I’m just under 30k. Notice it mainly happens if idling for longer than 5-10 minutes
Hasn’t done it for a while so I’ll deal with it once it’s more permanent
Summers22
Summers22
Jon
If the dealer won't replace it, Im thinking a few blows with a 3lb hammer as an experiment is worth a shot...lol
