Lift Problems *Solved*
ElBronc
WA
So I had 4 Wheel Parts install a 1 1/4" lift kit that I got from a different company. It's got the clunk over certain bumps, which the lift manufacturer acknowledged and sent me isolators (plate that was mentioned in another thread) that goes between the front strut top and spacer. Haven't had those installed yet.
I'm more concerned about another issue though. Accelerating straight up to about 20 mph and also while cornering, there a shake/wobble I can feel in the floorboard. I haven't seen anyone mention that issue after lifting the Sport, but has anyone had that issue? Or know what might cause it?
Fossil
Ernie
ohio
so, who was the "other company"?
ElBronc
ElBronc
WA
The lift came from a company called HRG Engineering.
ElBronc
ElBronc
WA
TnyM
Tony
Seattle
'77 Chevy c10, '22 Bronco Sport BL
Good to know.
Now really happy with the end result of the lift and 245/70R17 Falken Wildpeak AT3W.
Ford Bronco Sport Lift Problems *Solved* PXL_20211120_002255589.MP
So after the tire size increase and lift what is your over all gains, ? are they a 30 inch tire ? And what is your clearance now versus 8.8 . Thanks
Ford Bronco Sport Lift Problems *Solved* 40A7E88D-E819-492C-8229-FA4FD699D493
Ford Bronco Sport Lift Problems *Solved* 574DA774-9C5A-4C7A-ADE3-7B2A169D94F5
bgomez
New Jersey
How has it been driving on normal roads. Any increase in body roll etc?
Stock tires 235/65R17 measure 29", 245/70R17 are 30.5...so 1.5" difference(.75" lift).
8.8+.75+1.25" come to 10.8" ground clearance. Same as a Jeep Rubicon, I'm good with that ?
Is the lift required if you go with 245/70/17 on a first edition ? Thanks
ElBronc
ElBronc
WA
Really I don't know if the lift actually helped the tire clearance much. It seems like either way it would rub the wheel well liner a bit where the pinch weld is. I lifted it anyway to be safe and get the extra ground clearance.
