HVAC Problems
Not sure we haven't messed with it too much in that way. Just know when its hot outside it doesn't work thats about it
Probably should let the tech know - could send the tech down a totally different path
kthorg23
Karisma
Washington
21 bronco sport
When its working it doesn't tend to just shut off. Its usually just off when I start the vehicle and then takes a while after driving for it to usually turn on
kthorg23
Karisma
Washington
21 bronco sport
Hey so actually I wanna change the number we ordered i could have sworn it was the b but it looks like it was m1pz 19980 f
Please check the paperwork from the dealership and see what HVAC control module part # was replaced
you have a 2021 which could have the digital temperature on the dial(s)
Should have been one of these that’s applicable to your vehicle
M1PZ-19980-A w/Dual Zone Temp Ctrl.; w/o Heated Steering Wheel. Dual zone AC
M1PZ-19980-B w/Dual Zone Temp Ctrl.; w/Heated Steering Wheel. Dual zone AC
M1PZ-19980-C w/o heated seat. Bronco Sport; w/o Dual Zone Temp Ctrl.
M1PZ-19980-D w/heated seats. Bronco Sport; w/o Dual Zone Temp Ctrl
F superceded the B part
M1PZ-19980-F
Does this exactly match what you have in your 2021 Outerbanks?
Bronco Sport; w/Dual Zone Temp Control; w/Heated Steering Wheel. Dual zone AC, w/heated steering.
kthorg23
Karisma
Washington
21 bronco sport
M1PZ-19980-F
Yes thats exactly what I have
I sorta half expected it would be working when you start the vehicle and would stop later while driving which also relates to possible vibration of an electrical component as a source of the issue
But sitting at temps at or above 75°F for a while then starting the vehicle, hvac is not working but starts working later while driving fits with the possible causes I posted many messages ago (and could be vibration related as well)
Will be good to know if the tech (or you) finds that a low temp (75-85°F heat gun or hair dryer) applied to the exterior ambient temperature sensor or to the interior ambient temperature sensor or to the hvac module itself (from the knob’s side) will cause a working hvac to demonstrate the inoperable hvac condition you experience.
kthorg23
Karisma
Washington
21 bronco sport
Ya its guess I should have specified that from the beginning its only when starting
kthorg23
Karisma
Washington
21 bronco sport
Does the whole panel not have any power, including the ambient backlighting at night? The lighting comes from another source. The control function is tied one module, the lights to BCM.
The back lighting is also out when the problem acures so no power what so ever
dedwards0323
Dennis
Upstate SC
2021 Bronco Sport Outer Banks
On SAT, AUG 30, the HVAC System in my 2021 Bronco Sport Outer Banks stopped blowing cool air. AC light was on, but all the air flow was warm. Everything else within the HVAC Control Module seemed to be working correctly, just no cold air. Finally got an appointment to have the system checked out by a Ford Tech today and just got a call from the Service Advisor regarding the Bronco Sport. According to the Service Tech that worked on the SUV, the HVAC Control Module has failed and doesn't send a signal to the Compressor to turn on even though the light is on on the module. They say the entire HVAC Control Module has to be replaced and the new Module won't arrive until FRI, SEP 12. Only good thing about this is the repair is covered by the extended warranty that came with the Ford Certified vehicle & it's only going to cost me the $100 deductible. WHEW!
According to the Service Advisor, this is the first failure of the HVAC Control Module they've seen on a Bronco Sport. Service Advisor did say that assuming the part arrives FRI, I'll get the SUV back that afternoon.
kthorg23
Karisma
Washington
21 bronco sport
I have not hasnt been warm enough to test anything. Technician talked to one of the high service hotline people what ever you called them haha and they have never heard of the issue but apparently gave him some things to try come next summer
Lucky you it’s not that hot … here the AC goes on early March and maybe by December we can turn it off
kthorg23
Karisma
Washington
21 bronco sport
Almost wish it stayed warmer here longer we get like a month total of warmth haha makes it hard to figure out the problem
dedwards0323
Dennis
Upstate SC
Well the Ford Service Tech installed the new HVAC Control Module but the system still only blows hot air. Now they say there is a signal to the Compressor (which didn't exist before) but they suspect the compressor is bad. And according to the Service Dept, the compressor is on back order, so no telling when the Outer Banks get repaired.
I told the Service Advisor to have the Tech re-install all the interior trim & I would pick up the Bronco Sport. No point is letting them hold the SUV when I don't know when or if the replacement compressor arrives. Naturally, when I picked up the Bronco Sport, a piece of the trim located just below the HVAC Control Module is not installed properly. And a day later, my wife found a trim screw in her footwell that apparently had fallen out somewhere above. Absolutely shoddy service work! I Am told by the Service Advisor that both of these issues will be adressed whe I bring the Bronco Sport back for replacing the HVAC Compressor.
My 2021 Gold Certified Bronco Sport Outer Banks is slowly turning into a Ford POS SUV! But it is good to know that Ford employees in Michigan get to relocate to a brand new building for all their good work!
