GMRS Handheld Recommendations?
Looking to get a handheld first, then at a mounted unit later down the road (trail?). Any recommendations for a decent one, and any units to avoid? Units you later regretted buying (or not buying)?
Thanks in advance!
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
I've watched a number of his vids. I think I'm leaning towards the Tidradio TD-H8.
radios featuring tone scan is a plus
related subject
current project
NVIS inverted V 40 meter portable antenna
once the radio bug bites
some guys build bird houses
I'll in the basement constructing antennas
related subject
current project
If it weren’t ultimately a safety item, I could go the rest of my life away from ULF, LF, VHF, UHF, and HF. Too many years ruining my ears for Uncle Sugar and his crappy comm gear.
NMhunter
Albuquerque
BS Badlands
You didn't tell us what you want the radio for. I use Garmin Rinos for hunting. They are great because they have GPS and show the location of the person you're talking to. If you're just talking to your wife following in another vehicle, you may not need that.
Off-road use, mostly solo in the back country. Ability to hit repeaters is a high priority. The handheld is for initial use, will be installing a mobile unit down the road.
kshaw
Kent
Gaithersburg, MD
I got these Retevis GMRS handhelds for kayaking. They actually float if they fall out of the kayaks.
davidg4781
Same one. I also bought a magnetic antenna to make it a “poor man’s mobile” on the road: https://a.co/d/06rDk26A
Ok that's pretty neat. I was thinking of getting a Tackform mount to hand the mic from. That kind of antenna will help to just set the radio off to the side so it's not in the way.
Unicorn
Chester
W. WA
I've been having good luck with the Radoddity GM30. You can change antennas on them for different conditions.
