rocks
SC
OBX, '23 HR-V EX-L wife's
I had the spare tire face down with the standard hold down and it wasn't right to me. I'd rather have the full size spare front of the wheel up so I can check air pressure easier. The pic below is the shorter one in the Outer Banks. I had to buy the longer piece LJ6Z-17091-C Lug wrench stud for the Badlands.
It worked perfectly but I did add a piece of thick microfiber to stop and vibration scratches on the wheel.
Ford Bronco Sport Full size spare installed - tip 20230713_121157
Ford Bronco Sport Full size spare installed - tip 20230713_120459
davidg4781
Did you get a different floor board or just raise it to the higher position? I'd be curious what the difference is.
rocks
rocks
SC
I just use the higher position which I like. I never tried the lower position with the full size spare..
Badlands version
Ford Bronco Sport Full size spare installed - tip IMG_1986
REDWM
Doug
Western Colorado
2019 Ranger, 2011 F-150, 77 MGB, 2023 Bronco Sport
A quick question. If you put a full size spare in a Big Bend that has the emergency donut. do you have to raise up the cargo floor. I don't see any slots to use if you raise it.
rocks
rocks
SC
I have an OBX and used the higher setting before and after the addition of the full size spare. I like the floor being even with the cargo door lower trim. I never tried the lower setting.
Colonel Angus
Dean
New York
Quick question while we're talking about spares. Will a full size tire fit on the compact spare wheel? Thinking of using one of my Conti's as a spare when I upgrade my tires but, I'll need a wheel.
Generally not.
The rim width for most donut spares is 4" - 4.5", which is far too narrow for most full-size tires. For example, the Falken A/T3W 235/65R17 tire requires a rim width between 6.5" - 7.5".
Fsad
Frey
Portland, Oregon
Question...when you place a full size spare, the floor board/lid is now supported by the tire on the rear side of the vehicle, correct? Versus the plastic shelf supports when you had a donut in there. When I upgraded to a full size spare on my base model, I noticed that the floor board has no support underneath on the corners at the rear of the vehicle. Is that what you have as well? I'm thinking of adding some sort of 2" rubber bumpers/lifts on the corners to add some support.
rocks
rocks
SC
No problem with a full size spare here. The rear spare cover is in even with the rear bumper trim. Same as I had it with the compact spare.
