Exhaust rattle, dealership won't cover under warranty
MJbronco
Pennsylvania
BS BB
Had the Bronco in the dealership for the recall work. Mentioned to them a rattle in the rear exhaust area that I could hear while I was outside the BS. They called and confirmed they heard as well, didn't find anything loose but stated it might be muffler baffling loose internally. Around that time I had mentioned some damage near the front driver side underside of BS that was due to hitting tree limb. I only brought it up because I wanted them to know it wasn't something I was worried about. Around this time he told me the exhaust/muffler replacement wouldn't be covered under warranty, since he believed I was staying that I think I caused the damage somehow. I never stated the the other damage was related to the muffler damage. I didn't argue it at the time, but the more I think about it, I don't see how they can deny the warranty work for this. Not sure how to proceed....any thoughts?!
Take it back and have them correct the issue. They have the burden of proof to say it was due to your damaging the muffler, not you. If they continue to deny, ask for the phone number of the Ford regional service rep, and talk to them.
BravoAlpha
Oklahoma
Well, you already walked. Now they think they are right. You’ll need to go to a different dealership.
MJbronco
MJbronco
Pennsylvania
BS BB
But isn't dealership notes that can be seen by any dealership, wouldn't they just read the notes and deny warranty work?
jkeaton
Greatest country on earth!
This one
Did you actually get anything in writing that said they will deny warranty because they "believe" you caused the damage?
They can say whatever they want, but again, if they are denying warranty work because they think you caused the damage, did they explain or point out what they said you did to cause the muffler damage? If they think the tree limb that caused the front damage caused this muffler rattle, ask them to prove it. If they can't (or won't), then ask for the regional service mangers phone number and explain to them what you have posted to us.
IMO, they are trying to bully you. Unless you are leaving something out of the story, then I would not accept their actions.
rocks
SC
The basic warranty should cover it. Now if the muffler has marks on it from a limb hit...
sajohnson
Sherman
MIDDLETOWN, MD
Does the muffler have any visible marks/dents/scratches, etc?
If not, replacing the muffler should be covered -- assuming the tech's guess that the muffler baffling is loose is correct. They may want to confirm that before replacing it -- but if there is nothing obvious, like heat shielding too close to the exhaust, loose baffling is a good bet.
davidg4781
Oh! I remember hearing a rattling one day when it was on and I was walking behind the rear.
I'll check it out maybe tomorrow and see how my process goes.
Hi there, I'd be happy to look into your Bronco concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
Tina1106
Tina
Long Island
Hi - I have had this problem as well. I just left Ford dealership and they told me that I have to replace the whole muffler and that due to mileage it is not covered under warranty. When I asked what the issue was, I was told it’s an internal failure - wondered if this was possibly a recall issue as others have had the same rattling? I have a 2022 ford bronco sport outerbanks.
jkeaton
This one
Recalls won’t be happening for a failed muffler.
Tina1106
Tina
Long Island
Thank you- just thought I’d ask. Am total newbie at the dealing with my own car issues.
How many miles? Have you looked at the muffler yourself? If you are out of warranty consider getting a second opinion from an independent muffler shop.
If you are mechanically inclined and can find a rental bay with a lift it would make checking the exhaust system much easier, you can move around underneath the vehicle and bang on the exhaust with the palm of your hand or fist and find where the rattle is coming from. I had to do this a few months ago with one of my other vehicles, in that case it was a couple of exhaust clamps were a bit loose as I had previously dropped the exhaust to change out the motor mounts.
