Engine -- Dragon or MPC
RC Turner
Southern Minnesota
I am a new Bronco Sport owner and currently trying to find out all I can about my 2025 Bronco Sport. The current interest is in the engine. From what I can tell based on internet wisdom is, that the dragon engine is gone and has been replaced by the MPC. Is that correct? Also, what are the changes that were made to make it an MPC?
2025 Badlands Sasquatch
Google is your friend:
“Improvements to Ford's MPC engines include dual injection (port and direct) for better cleaning, a more efficient turbocharger, a redesigned EGR system, and a more robust construction to address past issues. These upgrades result in increased fuel mileage, improved emissions, and better performance across the 1.5L, 2.0L, and 2.3L engine sizes used in models like the Bronco Sport and 2025 Bronco.
Key improvements in the new MPC engines
  • Dual Injection:
    The engine now combines direct injection with port fuel injection. This dual-injection system helps prevent carbon buildup on the intake valves, a problem common in older direct-injection-only engines.
  • Turbocharger and Wastegate:
    A new, low-inertia twin-scroll turbocharger is paired with a high-speed electronic wastegate for faster response and improved efficiency.
  • Variable Valve Timing:
    A new, compact variable cam timing (VCT) system is used for better engine performance and efficiency.
  • Redesigned EGR System:
    The exhaust gas recirculation (EGR) system has been redesigned and integrated into the engine's block for a cleaner layout and improved efficiency.
  • Improved Reliability:
    Ford states that the MPC design is more robust and addresses some reliability concerns found in earlier EcoBoost engines, such as the potential for coolant intrusion.
  • Engine Options:
    The new MPC architecture is available in different displacements, including a 1.5L (Bronco Sport), 2.0L (Bronco Sport), and 2.3L (Bronco, Ranger, Explorer).
Performance and efficiency gains
  • Increased Horsepower and Torque:
    Specific models have seen gains, such as the 2.0L MPC engine now producing 250 horsepower and 280 lb-ft of torque.
  • Improved Fuel Economy:
    The upgrades lead to better fuel efficiency. For example, the 2.3L MPC engine in the 2025 Ranger has improved combined and highway mileage.
  • No Gasoline Particulate Filter (GPF):
    Some 2025 MPC engines, like the 2.0L in the Bronco Sport Badlands, are confirmed to not have a GPF, meaning they will produce their full horsepower rating.”
hellb0y
Hellish
BS
  • Dual Injection:
  • Engine Options:
Honestly all these performance gains translated into a bunch of nothing in the real world lol
RC Turner
RC Turner
Southern Minnesota
Thank you for the nicely detailed response to my query. I have owned several 2.0 Ecoboost Fords in the past. If this one is as good as they were, I will be quite happy. So far I am quite pleased with the performance, mileage, etc. The vehicle itself also seems to be well made.
Stircrazy
BC, Canada
2023 Bronco sport
  • Dual Injection:
the dragon has dual port and direct injection also
BLUEOVALRACER
  • Dual Injection:
  • Engine Options:
Thanks the best explanation of the differences in the engines I've seen.
RC Turner
RC Turner
Southern Minnesota
One thing I still haven't seen is a definitive explanation of the cam belt, oil pump belt, cam chain and gear driven oil pump situation. I haven't come up with anything that clearly states which system is used in the MPC engine.
NHD96
And what about the fuel injectors? Are they the same ones that crack on the 1.5 Dragon?🤔
Saw this posted by a Ford Mechanic: (please don’t shoot the messenger)
“2025 1.5L Bronco Sports use the Dragon B Engine which has been updated with Modular Power Cylinder (MPC) technology, but its still the 1.5L Single Turbo Dragon engine.
If anyone plans to argue that its Not a dragon, don’t waste your time. I work for Ford, I work on these engines, I know what they're called from the factory and in (repair manuals)”
NHD96
That may be true, but there are still plenty of differences. The only thing I can't understand is why Ford is hiding information about its engines, forcing people to theorize and speculate.
The information isn’t exactly hidden, it’s available to Ford mechanics and possibly may also be in the 2025 repairs manuals available for purchase (I haven’t checked there)
I concur with you that the info you seek may well be not available on the open internet without incurring a charge to obtain the information
