Bronco ForScan Thread
JKauf55
Tennessee
Ford Bronco
Thank you. yea I disabled it.. Bambi and double honk done. I am not able to do anything else.
You can! Just need to know where to look and (mostly trusting yourself on) what you’re doing.
Sldavid
Sankalp
Any pointers? What mods can be done? I tried doing a bunch of those today (windows open close with keyfob etc etc). nothing worked. Some pointers would be appreciated.
JKauf55
Tennessee
Ford Bronco
Make backups of all your “as-builds”!!! And not everything is going to work.
global windows won’t work without the proper hardware. I have Auto down only on driver side, but I do not have the DDM and PDM modules.
TBH, I won’t touch the “as-builds” right now and only look/try the in the non-as builds.
To enable the global window feature your car must be equipped with one-touch open/close on all four windows.
Black Rob
South Carolina
Thanks for this! I didn’t know what all the fuss was about, until now.
JKauf55
Tennessee
Ford Bronco
There probably are many more things but here are some:
4. Change number of blinks for turn signals (e.g. from 3 to say 6 blinks)
5. Climate controls appear digitally on the 8" Display..
think #4 has changed/can’t do anymore.
#5 having problems getting it to show. It showed once for me but when the unit restarted when doing the next step it went away.
with that being said when I originally did #5 I didn’t have the engine running when doing the Climate Domain and I went and rebooted the display unit (Holding Power + FF button simultaneously) this screen/icons showed. Any idea what the 2 icons are on either side of the heated steering wheel?
Ford Bronco Sport Bronco ForScan Thread IMG_4797
JKauf55
Tennessee
Ford Bronco
Yup, and have to have the DDM and PDM as well. If one doesn’t have them won’t it’s pointless
Sldavid
Sankalp
1. Eliminate engine auto stop/start
https://www.broncosportforum.com/forum/threads/disabled-auto-start-stop-with-forscan.3733/
2. Eliminate double honk when locking vehicle using keyfob
3. Change default parameters for tire size (i.e. when tires are changed out to a different size)
Example ECU settings for:
22565R17: 2202
24565R17: 2232
Bandlands, Falken Wildtrak AT3W (245/65/17) tire circumference: 2354mm (original value 2202)
6. Bambi Mode: keeps fog lights on when high beams come on
7. Splash Screen changed to Ford Performance
Note: for above items, Relearn PCM and AWD modules then clear the DTC codes
8. Add Bass to Rear Speakers (Bronco Sport 6 speaker system, unknown if works on any Bronco Sport B&O 10 speaker system)
9. Auto High Beam AHB Fade setting probably is in the API section:
Default: high beams come on full and off full or can be set to fade on full (takes about 2 seconds) and fade off (takes about 1 second)
Also don’t believe someone that states you can add additional GOAT modes to the non-Badlands (and non First Edition) models. That is for the full size Bronco not for the 1.5L Bronco Sport models which do not have the hardware needed for the additional GOAT modes that are on the Badlands/FE.
Did almost all of these but apart from bambi mode & double honk nothing else worked. I dont know how to change the flashing sequence. I did add the heated steering icon on screen but i dont think my BSBB is equipped wirh it.
Sldavid
Sankalp
One touch open is working but not one touch close. Is there a setting to make it work?
Sldavid
Sankalp
Yes i am also not touching the as builds modes. Dont wanna go to Ford for another messup
Push and hold the button in the close position for three seconds after the window is down. Do that a couple of times and it should reset the motor. You you need one touch on all four windows, not just the driver's window. If you don't have it on all four windows, you cannot enable the global windows feature.
Sldavid
Sankalp
Got it. Thank you
JKauf55
Tennessee
Ford Bronco
You do not. Not in the Big Bend!!!
However, do you have the red bottoms at bottom? If so you can put the heated seat icons on the Home Screen of the display. Look in APIM and filter/search Seat Icons.
Also be aware IF you have them and get the icons on the Home Screen of the display, every time you turn off the BS and turn it back on the screen will ALWAYS default back to the Home Screen. Made me crazy so I took them off lol
Ford Bronco Sport Bronco ForScan Thread IMG_4811
Sldavid
Sankalp
Thank you for the advice. I do have the heated seats options/buttons. If it is going to go back to the default screen then i would leave it as it is.
JKauf55
Tennessee
Ford Bronco
I mean it works. My ass sweated before I realized I hit the driver one accidentally while looking away when trying to press the Audio button instead lol
