Boost Gauge just disappeared!
TankKiller95
James
Tennessee
2025 Bronco Sport Black Diamond
The boost meter on my 2025 Bronco Sport Big Bend, just went away for some reason! Anyone else experience this issue? I have an appointment with the dealer for service on it, but just wondering if anyone else has encountered this problem.
Ford Bronco Sport Boost Gauge just disappeared! IMG_0489
Superdave
Dave
Minnesota
2025 Ford Bronco Sport
It needs to be in Sport mode to have to turbo boost gauge show.
TankKiller95
TankKiller95
James
Tennessee
Actually, it shows in both Sport Mode and Off Road. I’ve seen it and used it in both. But it isn’t showing in either mode.
BroncoBoy25
Ken
Tucson
It is configurable, you can add it, but only to the modes mentioned before.
2025 Badlands Sasquatch
Thank you! I found it in settings. For some reason it was shut off. I know it wasn’t me because I didn’t even know you could select which gauges would show! I got it turned back on though!
It seems that gauges resetting themselves randomly is a feature in the BS.
AZDesertrat
Kyle
Glendale, Arizona
2025 Bronco Sport Outer Banks
Just noticed it was missing on mine today too. Will have to look at the settings and add it back.
Ford Bronco Sport Boost Gauge just disappeared! IMG_4377
TankKiller95
TankKiller95
James
Tennessee
This must be a glitch in the system! Has anyone else had any issues with the controls on the steering wheel, or settings changing on their own?
rugedraw
Javier
Miami, FL
Just the 2025s
In a few years ford will have all those kinks worked out
Don't hold your breathe. The boost gauge on my F150 (also on Sync 4) likes to check out every couple of weeks and I have to put it back and it has been doing so for years. The cool thing with the F150 is the boost gauge can be there in any driving mode. But eventually, it will go away and get replaced with the trans temp gauge and I have to manually go in there and change it back to the boost gauge.
