Saaaame!Reverse tilt mirrors would be sweet! I would settle for that without the folding
It does, but when I tried to enable it, it didn't work. The toggle is still there in the APIM, but I cannot toggle it on. Now that I have the Sync 4 APIM, it may not work at all.Do you have a BS with memory in the seats?
https://www.broncosportforum.com/forum/threads/reverse-tilt-mirrors-worked.21435/It does, but when I tried to enable it, it didn't work. The toggle is still there in the APIM, but I cannot toggle it on. Now that I have the Sync 4 APIM, it may not work at all.
Interesting. You did it with easy mode. I can't believe I missed that post. I'll try it over the weekend or sooner if I get a chance to see what happens. The thing is, the devs added Sync 4 support to FORScan for the BS only because I asked them to since I have Sync 4 in mine (very awesome of them to do that). Not sure if easy mode will work in my vehicle due my GWM being a Sync 3 one and there are some communication issues even though everything works. Worth a try though......thanks!https://www.broncosportforum.com/forum/threads/reverse-tilt-mirrors-worked.21435/
If it still doesn't work, we'll investigate why it's not working until it does!![]()
You have to keep trying until it works! Yes, I posted it for you.Interesting. You did it with easy mode. I can't believe I missed that post. I'll try it over the weekend or sooner if I get a chance to see what happens. The thing is, the devs added Sync 4 support to FORScan for the BS only because I asked them to since I have Sync 4 in mine (very awesome of them to do that). Not sure if easy mode will work in my vehicle due my GWM being a Sync 3 one and there are some communication issues even though everything works. Worth a try though......thanks!
Edit: Oh, you just posted it.![]()
But... something very important. Do you have a mirror with a motor that allows it to fold?I'm doing something wrong. I was not able to replicate the mirror fold in another friend's BS.
I know this could be too much to ask but @pantera155 any chance to you give all changes is required and the modules?
I checked and compared APIM DCM PCM with my own and looks the same but not working.
Thanks pal
Oh yes. Back in Brazil the Badlands is the only version selling there. Both BS I tried are the same as mine, model, year.. with the motor.But... something very important. Do you have a mirror with a motor that allows it to fold?
Seu amigo quere trocar os espelhos sim motor por espelhos com com motor? Certo ?Oh yes. Back in Brazil the Badlands is the only version selling there. Both BS I tried are the same as mine, model, year.. with the motor.
All mechanicals part are good, we need the codes and areas to change using Forscan, that is the issue right now, the codesSeu amigo quere trocar os espelhos sim motor por espelhos com com motor? Certo ?
Ele ja tem os espelhos novos pra trocar?
