ASS - from X
Cobrablues
New mexico
2024 Bronco Sport Badlands
Forscan costs too much just to change the ASS option.
My finger pressing the ass DISABLE Is cheap.
I just renewed mine for a year. It was $20.00. But if you don't use it for anything else, I can see that. I have used it for other things like getting rid of that double honk and tire size changes.
Bill G
San Gabriel Valley, CA
I’m still “checking”, but I think both mph & mpg readouts have gotten more accurate since I put the 235/70 tires on my BL. I’ve made no other adjustments.
Reactions: Me3
Quashish
Tomas
Sacramento
I tried to disable it in my Badlands with Forscan but it wouldn't work. Forscan said it was disabled but it would still do it. I tried several times. I finally gave up and decided I would just hit the ASS button. Which, in retrospect, I kind of always liked hitting the ass......button, that is.
Check in the bcm and pcm. I think it was in two spots I disabled it just fine.
elvisimprsntr
Elvis
'25 BS BB
On the '25, it's in the PSCM
PID: 730-03-01 - Start Stop
Value: 0 - Disabled
Ford Bronco Sport ASS - from X PSCM ASS
Now if I can only figure out how to disable the seat belt status pop up on the cluster so I don't have to press the OK button on the steering wheel every single time.
Cobrablues
New mexico
Thanks. I will do that today and check back.
I got it done by rewriting the values in the PCSM module : PSCM 730-03-01 xxxx xxxx 00-
Nothing else worked. Every value that I disabled in all the other modules did nothing but lie even though it showed them disabled.. I am so very grateful for this forum where I can find valuable info.
I was about to go buy the freaking little LED night light.
Anyways...now I'm going to write a blues number about Lying Modules. After all aren't most blues songs about somebody being done wrong?
Thanks for all the help.
Cobrablues
New mexico
The 2024 BL doesn't have the module formatted that way. They made it easier because they knew we were going to do it.
Thanks for the post.
The LED night light doesn’t work for all owners that tried it - you might just be adding it to your blues number
