Anyone run 5w-30
Area51BS
Ron
Anyone running 5w-30 in warm environments? My other two Fords run 5w-30. Hate buying that 6th quart of 5w-20 for the 1.5 oil change and prefer to just keep 5w-30 on hand for all vehicles.
BobbyTony
Bob
Soon: 2025 BS OBX Now: 2019 Edge Titanium, 2014 F150 XTR, 2006 mustang GT
If only you used the metric system, we can buy 5L jugs. (In fact now I will only buy the BS oil from suppliers that pack it in 5L)
I want to say it won't hurt, and it probably won't, but there was a reason Ford changed it after learnings on earlier Ecoboost engines.
Given that’s the mfr’s recommended weight for the majority of applications, that’s what I go with. I do opt for full syn, though it’s not required.
bushbunnie
Al
Piney, Manitoba
2014 Ford F150 and a 2023 Bronco Sport
I do. In fact I use 15w40 in my F150 (3.5 L)
davidg4781
I was suggested to use a higher weight in one of my older cars when I was losing oil. I believe the thought was it was slipping past the piston rings and they thought the heavier weight would prevent that.
That tells me a heavier weight oil might not run as smoothly in an engine with tight tolerances. Personally, I wouldn't risk it if everything's working fine.
Area51BS
Ron
My understanding is the extremely light weight oils are to get the max mileage. So not to be penalized because of the CAFE standards. Same motor in another country with less strict regulations would run a higher weight oil.
bushbunnie
Al
Piney, Manitoba
I'm getting 7.6 L to 100 K highway driving and about 8 driving around.
GJarrett
Bradenton FL
2024 Bronco Sport, 2017 EcoBoost Mustang
That's my understanding too. So the logical question would be... what oil does Ford recommend for Bronco Sports sold overseas? (Or are they not sold overseas?)
rocks
SC
Honda 4 cyls get 5W30 abroad.
They’re also sold in Canada, Mexico, Argentina, Brazil, and Columbia. AFAIK, 5W-30 is the standard weight recommended globally, with 0W-30 recommended for extremely cold climates.
Foghorn
Canada , East Coast
Should / could you use something other than 0-20 ??
Best answer I have seen came from The Car Care Nut...
He said..." Will your car run OK on oil different from that specified by manufacturer ?"
" Do you wanna find out?"
Fog .
Nicktacular06
Nicholas
CancĂșn Mexico
Sport Sasquatch
I run the Mobile One 5w-30 full synthetic here in Cancun Mexico because it’s warm/hot year around with no issues.
rocks
SC
The 2.0L uses 5w30. The 1.5L 5w20.
