Deleted member 6591
- Thread starter
- #1
Is there any way to increase towing capacity on BS beyond 2000lbs?
Ok, let be just 2200lbs. Thanks omahafordowner. You make me laugh! But it is what it is...Sure,
You will just need to reprogram the vehicles computers, upgrade the radiator, suspension, brakes, axles, and intake/exhaust system.
curious if you remember where you sourced new wheels and axle from? I've been eyeing up that harbor freight trailer for hauling motorcycles around. Been casually watching for a coupon or sale on it. I really need something that can fold up for storage like that but isn't going to blow my bank account.I got and built the Harbor freight trailer.
the axle and wheels were crap.
Balancing the wheels was impossible. Chinese made crap at itâs worst. The thing vibrated bad, wheels out of round, axle splines were welded crookedly so tracking was embarrassing. I got a proper axle and good wheels and tires then the thing pulled straight and smoothly. Used it for years, sold it when I moved for what I had in it due to the far better axle.
RED NECK Trailer supplies.curious if you remember where you sourced new wheels and axle from? I've been eyeing up that harbor freight trailer for hauling motorcycles around. Been casually watching for a coupon or sale on it. I really need something that can fold up for storage like that but isn't going to blow my bank account.
Awesome, thanks a bunch for all this info.RED NECK Trailer supplies.
Itâs a Legacy now known as Dexter⊠Google Red Neck trailer. :âP
Mine was the larger of the two models 4x6 I think,
It was a one man operation to fold it up and roll it in the garage. NOTE: I added larger castors to roll it around on due to the expansion joint in my drive way. LEVEL concrete only as the folded rig is too heavy.
Secondly, re engineer the strap system to secure it up when folded or you could get seriously hurt !
3rd do NOT splice or clamp into your vehicles wiring/ lighting harness even at the tail lights. Thread a fused red power lead (18 gage automotive wire is what I used), fuse link should be within 2-3 inches of the battery. Buy the FORD plug in harness, chassis ground is fine. So only one red wire to the batteryâŠ..
Lastly the stock box axle is trash but would make a great yard cart. Also spring for the grease point axle hub covers.
They are easy to tap in with a rubber Hammer, tap easy and keep âem straight all the way in the hub. When they collapse half way in grease em up full again.
Harbor freight doesnât do coupons anymore. The folding trailer that has a 1,750 capacity is $549. I think itâs has improved over the years. ?âcurious if you remember where you sourced new wheels and axle from? I've been eyeing up that harbor freight trailer for hauling motorcycles around. Been casually watching for a coupon or sale on it. I really need something that can fold up for storage like that but isn't going to blow my bank account.
they still do coupons, they are just only online now:Harbor freight doesnât do coupons anymore. The folding trailer that has a 1,750 capacity is $549. I think itâs has improved over the years. ?âmost people will weld the trailer shut otherwise it rattles loose?
