Add Auto-wipers? "WORKED!"
Javier
Miami, FL
Here I show what's under the lid
The main cable has unused wires. Could those be the rain sensor wires?
Does anyone have a photo with the sensor attached?
If anyone has the electrical diagram, I would appreciate it!
Very thanks!
Hopefully this helps:
Ford Bronco Sport Add Auto-wipers?  "WORKED!" 1762365171042-6d
Ford Bronco Sport Add Auto-wipers?  "WORKED!" 1762365223573-cq
Ford Bronco Sport Add Auto-wipers?  "WORKED!" 1762365287620-15
pantera155
pantera155
Pantera
Argentina
Bronco BADLANDS 2025
Excellent help!
I'll start gathering information so I can install the sensor when it arrives.
It would be very helpful to know what each wire in that connector is for.
Ford Bronco Sport Add Auto-wipers?  "WORKED!" Conector
Javier
Miami, FL
Excellent help!
That looks like connector C922, but the info in PTS on it does not seem to be very helpful.
Ford Bronco Sport Add Auto-wipers?  "WORKED!" 1762379338185-lj
cprcubed
Patrick
Parker, TX
If the Bronco Sport has an Electrical and Vacuum Troubleshooting Manual (EVTM) like other Ford vehicles I'm used to (albeit they're older vehicles), they will typically only show the circuit numbers for larger connectors. Then one needs to go through the various "system" diagrams (engine control, abs, airbags, illumination, etc) and find the circuits. With the electronic versions of the EVTM, one can search on a connector and it will show the various systems associated with it. It can be tedious and time consuming. Cheers!
Javier
Miami, FL
Very tedious, indeed. PTS is not very user friendly.
kshaw
Kent
Gaithersburg, MD
Check FORSCAN, the rain sensor capability may be built into the car already but just needs to be turned on.
pantera155
pantera155
Pantera
Argentina
While there's no data for each pin, the wire colors are helpful!
Update thanks to the information provided.
The female connector is missing 3 wires. Those 3 wires are for the rain sensor. I tested them and there is 12V.
I've already connected the wires to the female connector.
All I need is the rain sensor; connect it and program it with Fodscan, and it should be working!
Ford Bronco Sport Add Auto-wipers?  "WORKED!" photo_2025-11-06_23-56-10
Ford Bronco Sport Add Auto-wipers?  "WORKED!" photo_2025-11-06_23-56-07
Ford Bronco Sport Add Auto-wipers?  "WORKED!" photo_2025-11-06_23-56-03
pantera155
pantera155
Pantera
Argentina
Update! Rain sensor installed and programmed in Forscan.
But nothing's happening! :facepalm::facepalm::facepalm::facepalm:
The data cable reaches the steering column. The sensor has voltage...
Something is missing and I don't know what it is. :curse:
Ford Bronco Sport Add Auto-wipers?  "WORKED!" photo_2025-12-12_01-23-41
Ford Bronco Sport Add Auto-wipers?  "WORKED!" photo_2025-12-12_01-21-58
pantera155
pantera155
Pantera
Argentina
Is there a change in voltage on any of the signal wires in dry vs rainy conditions?
I'm going to measure tomorrow.
I don't know how it works, I suppose it's a variable voltage between 0 and 12V
Thanks!
NHD96
pantera155
pantera155
Pantera
Argentina
pantera155
pantera155
Pantera
Argentina
Things are going badly!
The sensor I bought was faulty!
I realized while testing that the infrared LEDs weren't lighting up. And when I measured, it was returning the same supply voltage...
In the video, I test an LED with 1V and it lights up.
What a waste of time! Now I have to buy another sensor and try again.
You reap what you sow.
:crying:
Ford Bronco Sport Add Auto-wipers?  "WORKED!" photo_2025-12-13_01-12-41
Ford Bronco Sport Add Auto-wipers?  "WORKED!" photo_2025-12-13_01-12-38
Ford Bronco Sport Add Auto-wipers?  "WORKED!" photo_2025-12-13_01-12-43
@pantera155 is a good working rain sensor supposed to simply change its output voltage when rain is detected vs no rain detected? Basically being ”on” or “off”?
