2023 Escape dash with Sync 4 and larger center screen.
Head up display like the Escape.
360 degree camera view.
Forgot 1 thing, a power tailgate would be nice. Possibly eliminate the glass panel opening. I don't use it much and just another source of water leaks.
Arcee
Southeast, PA
In order of my biggest wants:
1. Metal bumper (preferably with winch). Would buy this instantly.
2. Additional bull bar options for the BL besides Rally Innovations
3. Additional tail light replacement options to compete with Archaic (Love the look but $340 for Chinese manufactured tail lights with no warranty is hard to swallow)
4. Integrated switch panel like on the full size Bronco
5. RGB Oracle "Bronco" Lettering. I love my white ones, but to change the color at the push of a button would be downright incredible.
Rough Country offers a nudge bar for the BS
https://www.roughcountry.com/ford-nudge-bar-51040c.html?find=2022-ford-bronco-sport-4wd-856087
Elegance
Kris
Tawnygal
TK
Wenatchee, WA
www.tonyadoughty.net
2021 Bronco Sport FE, 2021 Bronco Outer Banks
Goose Gear Seat Delete System
I want to start traveling/ site-seeing. I’ll probably start with 2-3 day outings to state parks etc. (not quite rugged over-landing)
The idea is to combine the G.G. system with the deep sleep mattress, secondary battery (all in one), portable fridge, minimalist cooking setup etc.
As a Bronco Sport car-camping enthusiast, I am REALLY wanting the same thing as you!
Pop in window screens. Yes, I know there are universal fit ones that go over the door. I want some that pop into the window track. I have seen custom fit shades that do it. I'm even thinking about getting those and redoing the wireframe with screen somehow. If you own a Cyber Orange Bronco Sport, you know how much you have to fend off the flying bugs.
A whip flag mount that can just clamp to the roof rail. The roof rail on the Sport is an obnoxiously thick diameter and decidedly not round at all, so nothing on the market can clamp to it. Same can be said for the factory crossbars. I have been working on fabricating my own.
Molded wheel liners in something other than luxurious velvet felt. Yeah, it cleans up well enough with the pressure washer. Regular hose cleanup would be just so much nicer to deal with.
A no cost, no payments needed option.
RushMan
Russ
NW NJ
'24 Shadow Black Badlands
Something like this?
https://www.ebay.com/itm/175668319628?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&_trkparms=ispr=1&amdata=enc:1H_G1mg4nTX-T_N3DzHDPCQ1&campid=5338969497&mkevt=1&mkcid=1&toolid=10050&customid=cefb454064921f0e7c1f2192429a399f&mkrid=710-53481-19255-0
Alfa 2407
Thomas
I am looking for the same thing, at this point I have decided to make my own by using some form of plastidip, epoxy, or something to that description to coat the factory ones, still not come to a conclusion on what I will be using, and anyone who says, "that's going to add a lot of weight to the car", in advance, my response, im aware, but what's heavier, a little bit of plastic coating, or soaked/mud caked fender liner?
The "pays for itself" feature.
TEdison
2025 Bronco Sport OBX / 2020 Lincoln Corsair
https://www.ebay.com/itm/204141809834
I made an offer of $275 and the seller excepted…shipped from Los Angeles…exactly the same as the Archaic....they fit perfectly…check out the listing and see what you think.
Dynamic turn signals (and tail lamps) are not DOT or SAE approved and do not meet FMVS 108 lighting requirements (no matter what the seller may claim). Sequential turn signals are legal, but those do not qualify as being sequential inasmuch as each lighting element must be at least 22 sq. cm. A single LED is considered a lighting element. They would likely qualify if all of the turn signal LEDs lit on what the DOT calls the "surface area of the first flash". Hopefully you live somewhere where no one cares...just remember, if you get rear-ended, they're gonna say it's your fault.
the.harold.c
Chris
TN
you may want to reach out to Cascadia and see if they’re planning on a BS panel. They’re the OGs of those in the overlanding space. Hood panels are more expensive than comparable rigid or even flexible panels though…https://www.cascadia4x4.com/collections/vss-system-hood-mounted-solar?page=2
I finally made time to reach out to Cascadia 4x4, inquiring about a BS specific solar panel.
They are apparently working on a new panel for the sport, available in the spring, that will be “worth waiting for”.
