pixlpush
Portland, OR
2025 Badlands Sasquatch, Desert Tan
I spent about 5 hours meticulously washing, drying, clay baring, polishing and applying Griots 3-1 ceramic wax on Sunday. The prep is time consuming but the application of the 3-1 wax was about as easy as it gets. Just don’t over apply it and do it inside or in the shade. A unexpected benefit was it doesn’t dry white on black plastic trim like a lot of wax and polish products.
Then because I live in Oregon, it rained the whole next day 🌧. Water beading to die for though 😊. Will see how it holds up but so far so good. I’m not expecting pro ceramic coating longevity but as long as I get a few months I’ll be happy.
Ford Bronco Sport SiO2 ceramic coat + rain = water beading extraordinaire! IMG_3759
Ford Bronco Sport SiO2 ceramic coat + rain = water beading extraordinaire! IMG_3758
Ford Bronco Sport SiO2 ceramic coat + rain = water beading extraordinaire! IMG_3760
disciple83
Andrew
Nashville, TN
2025 BSB Eruption Green, 2022 Forest Green Edge Titanium
I've only had Hallie a week, and it's been raining cats and dogs the whole time, so I haven't had a chance to put anything on her. Plus I got her gently used so I have to do a little correction first. But I wanted to put this out there. Hope it helps. Since you didn't get a 24-48hr cure window to help create the crosslink bonds it normally would while air drying, I'd expect a reapplication somewhere closer to 4-5 months instead of the whole year. But it is definitely a budget and elbow grease-friendly solution.
Fun fact, you can stack it on top of Carnauba. Get the deep gloss shine with harder environmental protection and persistence.
Ford Bronco Sport SiO2 ceramic coat + rain = water beading extraordinaire! 1781022499493-d2
North_of_49
Glenn
Edmonton AB Canada
When I bought my ‘25 OBX last fall I wanted to get something quick on the paint and wheels for the winter because of the large amount of salt that gets put on the roads in my city. I had access to the garage at my work for half a day and put a paint sealant on first then the Griot’s ceramic 3-in-1 as well as their glass sealant. Only one application of each due to limited time but figured it would be better than nothing. Got crazy water beading right after doing that.
Half a year later I’m ready to start from scratch and do both again but this time more than one application each. I have a Griot’s product that my local high end detail shop and store uses to get waxes and sealants off and back to virgin clear coat and have clay bar + lube and fallout remover ready to go too.
But what I wanted to mention is that although I’d lost most of the water beading over the winter, lately I’ve been using Griot’s ceramic quick detailer (ceramic Speed Shine) between washes when the car isn’t actually dirty enough to need a proper wash and I’ve been getting really good beading again (it’s rainy season here) even 2 weeks after application and that’s just with their quick detailer (the ceramic one, not the older Speed Shine)…
Really impressed with Griot’s products.
airems
Jeff
Show Low AZ
I thought water "sheeting" off the paint was the new water "beading" of today's world?
disciple83
Andrew
Nashville, TN
It's the volume of water hitting the hydrophobic surface that creates the sheeting effect. Take the nozzle off the hose and have it spray the surface for sheeting.
wireman
Murrieta
I use the speed shine detailer also. When the BL is clean and before using it I use a California Duster to get most of the accumulated dust off. Griot’s have quality products.
TNFurb
Nashville
I also use the Griot’s 3-1 ceramic and it’s great. It lasts me quite a long time. At least 6 months if not a year. But I don’t live in a rainy climate like you.
VinnyLongPour
Vincent
Long Island
2025 BSBB & 2023 Bronco Wildtrak
disciple83
Andrew
Nashville, TN
Larry Kosilla is waking up in a cold sweat with all this California Duster talk.
