Back UP Camera Image display
JRES
VT
bronco sport
Hi all,
I have a 2024 Bronco Sport with 25K miles on it. Have noticed that the display is not all that clear lately even after cleaning the back up lens. Took it to my dealer for other service and i mentioned it to them. They took a look and said the back up lens is scratched and not covered under warrant. I am in VT and drive on dirt roads, and with my prior vehicles never have had such an issue. The are wanting over $600.00 dollars to replace the camera. Any one with such an issue., and suggestions.
Thanks
Hi all,
Thanks
It took me a long time to even start using it. I guess one of the good things about being as old as the dinosaur. None of the auto Nannie’s even existed for most of our driving years.
Personally, I prefer the rearview mirror. That does require the rear window to be clean.
You could look into some polishing paste to see if that would clean it up.
bronc 2025
Thomas
2025 Ford Bronco Sport
I have a 2025 with a bumper to bumper warranty if my dealer tells me something is not covered I'm going off!! Call Ford and if necessary call a lawyer
Robins21
Horse Pasture, Virginia
If the backup camera lens is scratched that is damage & is NOT covered under warranty. Why call a lawyer for something that is not covered?
51brekbronk
Jeff
2023 Ford MAverick
Hi all,
Thanks
Same issue with my 23 Maverick. Blurred image and lens clean. Ford dealer replaced under warranty. If they won't honor it then I think its pretty easy to replace yourself.
Whpony96
Scott
Nampa, Idaho
Hi all,
Thanks
Do you use a car wash by chance?
Bill G
San Gabriel Valley, CA
Hi all,
Thanks
Don’t know what mater the lens is made out of, but you might try one of the headlight restoration products (don’t use the power polisher šŸ˜) or some jeweler’s rouge to polish out the scratches. Might not work, but what have you got to lose?
TheDude
Tampa, FL
Hi all,
Thanks
I had something similar happen with my former Lexus. A small rock just happened to my camera while driving one day and cracked it. I tried very hard to get it covered under warranty, but had no luck. Unless you can prove the camera lens itself failed it's not going to be covered and that's not going to happen. I ended up having to shell out $1100 for mine. I could have bought the camera itself, but it was the same price as the dealer and it had to be calibrated which I could not do. $600 isnt a bad price imo, but if it has to be calibrated that's probably going to be more. See what online places like Levitown Ford is charging for the camera and compare to what the dealer wants installed and calibrated. Might save some money buying it then having them install it.
