Not happy with my defrost - a bit strange
TCBSport
Pennsylvania
2023 Bronco Sport, 2012 Land Rover LR4 5.0L
This winter my 2023 Badlands has exhibited a bit of strange behavior with the windshield fogging up and not completely clearing up unless I put it on max defrost which is annoying with the fan at full blast. It's not a dangerous complete fogging but it is enough to notice and be annoying. My coolant level is fine so no heater core issue and even on the standard defrost setting when I put my hand up on the dash the air is blowing warm. Has anyone had similar behavior? Maybe I need to treat the inside of my windshield with something?
DonImbimbo
Don
Wellsboro, PA
It could also be a slight leak in the A/C system. That comes on to help the defog.
Robins21
Horse Pasture, Virginia
Also try routine cleaning of the inside of the front windshield. If your BS sits in the sun the chemicals that are in & used to make the dash top will out-gas & leave a film on the inside of the windshield. I routinely clean our 21 BS/BB & my 05 F-150. It happens on all make vehicles.
Javier
Miami, FL
Reset your sync system. HVAC is controlled by sync, it may fix the problem.
The HVAC has it's own module. In the case of the 2025 like yours, the a/c controls are on the touchscreen and not seperate like on the 21-24 models, but the HVAC is still managed by a seperate module and not the APIM itself.
AlanMac
Alan
mountainpacker.com
2025 Bronco Sport, 1970 Mustang Mach1
Good to know., thanks. My left dash vent lets air thru it when only the under dash vent it on. I reset my sync to no avail. So maybe I'll have Ford service look at it sometime.
Me3
Paul
Northern Nevada
RAV4
Is your a/c off? I don’t remember exactly how those controls work, but the windshield clears much faster and stays cleared if the a/c button is on.
You’ll still have warm air but the a/c pulls the moisture out. And make sure the recirc. Is off.
FNR8DRZ
Ron
2025 Ford Bronco Sport
Do you run the defroster with the AC on? I haven't noticed your issue in our Bronco....but....
I have this issue in my 23 VW. I was told to run defrost with the AC on at your desired temp. It works for me. I guess the AC blows at a lower humidity.
MB_Ray
Winterpeg
2025 Big Bend Black Diamond
Yeah, I've been noticing this too. Brand new 2025 BSBB. Very annoying.
I'm new to this. How does one do this? Thanks!
AlanMac
Alan
mountainpacker.com
AI so it maybe correct? You could call yuor local ford service dept to varify. To reset the HVAC system on a 2023 Bronco Sport Badlands, hold down the Power button (center of the volume knob) for up to 10 seconds to reboot the control module. Alternatively, for deeper resets, try holding the Power and Defrost buttons together for 5 seconds, or disconnect the negative battery terminal for 10-15 minutes.
TCBSport
TCBSport
Pennsylvania
This was the solution! Thank you for this info as I had yet to clean the inside of the windshield. I cleaned the drivers side half first to test and sure enough it is now as clear as it could ever be while the passenger side remained a bit foggy.
Robins21
I am glad it worked to solve your problem.
