Raptor grill accent lights
Pmk1710
Peter
Did you splice into the parking lights? Or run them separate into a lighting control for your other lights?
they are low amperage, so I don’t think there would be an issue if you did splice into the parking lights.
I didn’t splice into them though. I had a 6 gang rocker switch that I had installed primarily for the 7” 3-way lights, so I just ran the raptor accents into the controller for the switch panel. They are running on a 10 amp relay and have full brightness.
Because the Controller needed a fuse tap into a key start fuse for switch panel LED power, I leave the rocker switch for the accents on and they power on and off on their own when o start the car.
madfella
El Paso
I spliced into the driver’s side front parking light and it worked perfectly.
Ford Bronco Sport Raptor grill accent lights ED3EE127-ED87-43B3-9BC6-056E68DE0AE6
DaveInSA
Dave
San Antonio, Texas
2021 Bronco Badlands
Exactly which lights did you use? Have a link to them?
Pmk1710
Peter
Nice! I didn’t want to mess too much with splicing after reading a bunch of wiring horror stories with the BS. Glad it worked out for you!
ChefDank
Nick
New York
Looks great!
A winch would fit perfectly in between your nudge bar lights?.
Ford Bronco Sport Raptor grill accent lights Screenshot_20220415-112959_YouTu
I would never use that winch; that bull bar isn't connected to the frame as the tow hooks do. Looks great but might do some damage if used.
madfella
El Paso
It was actually pretty easy. Just make sure your connection is water tight. I used these:
Wirefy T Tap Wire Connectors Kit - Electrical Connectors Kit - Spade Terminals - Quick Splice Disconnect Wire Taps - (120 PCS 22-10 AWG) https://www.amazon.com/dp/B077YB123S/ref=cm_sw_r_cp_api_i_6BTE9DW13XN4FA07ERYD?_encoding=UTF8&psc=1
kyle_conrad
Kyle
Richmond, VA
kyleconrad.com
2022 Bronco Sport Outer Banks
This thread just makes me want light up BRONCO letters on the front more than ever.
