Rough Country 1.5" lift kit installed
CrashBend
I installed the Rough Country 1.5" lift kit on my Outer Banks. It works very well. Rough Country sku: 40100. I have 29" tall 10" wide tires (255 55 R18). Next week I will have U-Haul install a hitch. Curt Class 3 Hitch 2" receiver sku: 13474.
Ford Bronco Sport Rough Country 1.5" lift kit installed Rough Country Lift 1.JPG
Ford Bronco Sport Rough Country 1.5" lift kit installed Rough Country Lift 2.JPG
Ford Bronco Sport Rough Country 1.5" lift kit installed Rough Country Lift 4.JPG
rmreid22
Bob
Western TN
Did you take before and after measurements from the ground to the fender lip?
CrashBend
CrashBend
No. I did not think of taking any measurements. Guess I should have. Here is a before photo for comparison.
Ryan
United States
Curious as to how long your Rough Country lift holds up, I installed mine this week and ~40 hrs later and about 30-40 in town miles it has severe front rattle already. Sway bars are in tact, so I’m assuming it’s the design of the space on the strut (that almost everyone else is complaining about). I ordered the HRG lift and it’s on its way.
CrashBend
CrashBend
When you get your hitch let me know how you like it. I need to get one and haven't decided if I want to have Ford do it or not.
I had my hitch installed at the U-Haul service center in Vacaville. The guy did a great job and it was only about an hour to put it on. It looks like a factory install and no indications he took the back facia off to do it. My local Ford dealer, Elm Ford, service manager refused to take on any after market parts installation. In fact he was rather rude about my even asking if they would do the work. No going back there for even an oil change.
CrashBend
CrashBend
So far so good on my lift kit. I guess time will tell.
Jeremy
Curious, is the rattle like a serious problem or is it more of an annoyance type problem.
BlueBayeux
Holly
Dallas, TX
2022 Bronco Sport Badlands, 2007 Cadillac Escalade
From all of threads I've read on here, it 's a design problem that RC has yet to correct and many have been so bothered that they replaced with the HRG Lift. It sounded like enough of a problem to me that I will opt for HRG myself (when I get my BL). People have had parts snap too and have posted pics.
Jeremy
Well that kinda blows lol im getting that lift and i was hoping it was more just a rattle rather than something that could cause alot of damage.
CrashBend
CrashBend
Up to now, with a few hundred miles, I have not noticed any problems at all with the lift kit. Totally unrelated to the lift kit or installation the mounting bolts for the front sway bar became loose and had to be retorqued. That did cause a rattle and clunking noise. Not sure why they became loose. That was at around 7500 miles. Factory oversight maybe? We do very mild off roading. Dirt roads, soft sand kind of things.
CrashBend
CrashBend
I had U-Haul put the hitch on. Took only a couple hours. They used the 4 bolt direct mount. Great installer, he made it look factory. I only do very light hauling with the OB.
BlueBayeux
Holly
Dallas, TX
Well don't feel totally discouraged. Lots of people have that lift. Maybe read through the threads to see under what circumstances/conditions people have had issues and hopefully there are some solutions. I know the rattling issue is a design flaw but I don't think that that in and of itself is problematic. If you can back out, that would be optimal. Nothing sucks worse than paying for an upgrade that brings you misery. Good luck and keep us posted with your experience.
Bdud
Brian
Chicago
Why would they when they sell an oem hitch?
Unless they have fixed it, the strut spacer is putting all the load through the bolt at the top of the strut, instead of through the “hat”. That single point of support, instead of a big round ring, is a very bad thing. I think the noise is coming from the whole thing bending on the single point of support.
The other issue is the little brackets they supply to move the attachment point for the sway bar endlinks. Those brackets have broken for some. If I purchased one of those lifts, I’ll be looking for sway bar endlinks that are the right length (or adjustable to the right length).
Jeremy
Driven close to 500 miles already with no noises or problems of any kind. Maybe that will change though once i decide to go on trails or rougher roads.
