- First Name
- Josh
- Joined
- Apr 16, 2021
- Threads
- 18
- Messages
- 373
- Reaction score
- 400
- Location
- New Hampshire
- Vehicle(s)
- Ford Bronco Sport
- Thread starter
- #16
That's looking good!
What brad are the lights on the bar?
Audexen 7” work lights - based on the mount bracket angle and their size, I had to offset it just a tad. I grabbed some 2” metal joiner plates, drilled out the holes larger to fit the mounting bolts. I just need to powder coat them (and probably all the mounting hardware) and it’s will look fairly clean. No huge rush to get that done though.That's looking good!
You might have sold me on the mesh overlay.Audexen 7” work lights - based on the mount bracket angle and their size, I had to offset it just a tad. I grabbed some 2” metal joiner plates, drilled out the holes larger to fit the mounting bolts. I just need to powder coat them (and probably all the mounting hardware) and it’s will look fairly clean. No huge rush to get that done though.
Here is a photo of the offset I had to do for the lights. The mounts on the nudge bar are set at a 45 degree angle after install. With the brackets installed for the lights, the lights would not fit correctly, they would point down to the street.You might have sold me on the mesh overlay.
Same here. I'm thinking the mesh would be great over all the openings.Here is a photo of the offset I had to do for the lights. The mounts on the nudge bar are set at a 45 degree angle after install. With the brackets installed for the lights, the lights would not fit correctly, they would point down to the street.
So, I Jerry-rigged this offset and it works perfectly fine.
no, I didn’t have to take the grill off.The entire bumper/grille is one piece that takes a lot of effort to get off.Same here. I'm thinking the mesh would be great over all the openings.
Did you take the grill off to do the lights?
I haven't found a grill removal video yet but i'm going to dive into it soon. Maybe I'll video it.
Can you share the information on the engine compartment fuse for aftermarket lighting i think that would be very helpful not only to myself but many others also. ThanksI've had a set of lights for months and now with the weather breaking I am about to tackle installation...Research I found is there is a fuse in the engine compartment for aftermarket lighting that will shut off like driving lights...a simple fuse tap for these is what I plan to try...coming in and out of fuse panel is the only thing I have not decided on...any input?
we all saw that fuse in the engine compartment. But researching throughout the forum, everyone has expressed that the engine fuse box and wiring is a nightmare.Can you share the information on the engine compartment fuse for aftermarket lighting i think that would be very helpful not only to myself but many others also. Thanks
Tapped into Number 3 trying to get it across to drivers side any tips. Yes engine compartment box looks like nightmare. and trouble. Anybody know where the wires are located for the aftermarket lighting fuse.we all saw that fuse in the engine compartment. But researching throughout the forum, everyone has expressed that the engine fuse box and wiring is a nightmare.
you’re better off getting a relay control box and a separate switch. Some switches have backlit displays where you would run a fuse tap into fuse #3 in the passenger side interior panel.
the only splicing I had to do with all the lighting I added to my BS was small side marker turn signal lights in the air vent clip ins. I spliced those straight to my headlight turn signals because they drew less than 2amps. But everything else I did was into a separate relay control tapped straight to the battery.
what are you trying to power?Tapped into Number 3 trying to get it across to drivers side any tips. Yes engine compartment box looks like nightmare. and trouble. Anybody know where the wires are located for the aftermarket lighting fuse.
https://fuse-box.info/ford/ford-bronco-sport-2021-fuses/ampCan you share the information on the engine compartment fuse for aftermarket lighting i think that would be very helpful not only to myself but many others also. Thanks
