Factory mats sliding around on plastic floor - anyone have luck fixing?
Long Beach, CA
'22 Bronco Sport, '20 Jeep Gladiator, '99 SLK230
I have a problem with the plastic floor in my Badlands: The floor mats slide all over the place - same with cargo. What solutions have you found to fix this? 3M Velcro does not stick to this stuff. Ready to toss the factory mats for some rubber ones.
Slingy
Ben
North Of Boston
Which floor mats are you using? The carpets or the rubber mats? The rubber ones do snap in place. I haven’t been using my carpets due to the New England winter so I forget if they slide or not but I have no problem with the rubber mats sliding.
Long Beach, CA
Our Badlands has small posts on the floor that our mats attach to. We have the rubber floors and both our factory carpet mats and our accessory rubber mats stay in place perfectly.
Ford Bronco Sport Factory mats sliding around on plastic floor - anyone have luck fixing? Screenshot_20220228-154858_Chrom
I have the standard carpet ones, and my drivers' side is fine - mounts in place on two posts just like yours. The other ones though... Front passenger side has one post that it swivels around on, and the back are completely useless. They spend more time bunched-up under the front seats more than anything else.
Betsy
Brad
Saskatchewan Canada
The accessory rubber Ford ones like I pictured seem to stay in place pretty good - probably because they are made to fit alot better than the carpet ones. We only had those carpet ones in for a couple of days before we switched them out.
Geelloo90042
Angelo
Los Angeles
2021 Ford Bronco Sport-Badlands
This might seem too much, but try adhesive rubber strips under the carpet, with the sticky adhesive side facing the bottom of the carpet mat. So you'll have friction against the rubber flooring. I would try an x pattern to get all directions of movement
Long Beach, CA
Tried multiple adhesives on the floor - nothing sticks (which is impressive, but not exactly the result I was hoping for, LOL).
Long Beach, CA
What's the part # on those? Back seat floor too? Those are nice, just going to order some and be done with it.
Fossil
Ernie
ohio
you could try a bead of silicone caulk. try one bead on the underside of the carpet for a trial. let it cure completely before putting it back in the Bronco.
I've done that on carpet runners at home, keeps them from slipping around but they peel right up for repositioning.
BravoAlpha
Oklahoma
I intend on not using mats at all.
…If I ever get a Bronco Sport to put mats in:D
Flash3x
SWPA
2015 F350 Platinum
MP1Z7813300BA
That should be the right number for the rubber floor version in the BL.
We have them, they are nice. No issues with them moving around.
Poolmanz Sport Bronco
Bruce
Castro Valley, CA
sites.google.com
'21 Bronco Sport FE Area 51
The passenger side carpet mat would always move out of place.
I removed them and install the molded all-weather one.- all good.
This is the better choice. I am sure some person in marketing thought it great to sell more molded mats if they gave us "crappy" carpet mats....it's working. :thumbsup:
bbbronco_in_LBC
As some others have said, are you sure you have the floor mats that come with the Badlands?
My front carpeted mats snap onto the rubber flooring, the rears don't snap down, but they don't/haven't moved an objectionable amount.
Bronclahoma
Oklahoma
Same here.
