- Thread starter
- #31
Nice hearing your story about your bronco awd experienced.When I stop my BS in the middle of my steep loose gravel climb I can briskly restart just like I was on level pavement with absolutely no loss of traction on any of the four wheels.
I did this once with ice under one front tire on this steep section up to my house.
If it slipped I didn’t feel it. The other three took over.
I did this again with both right side tires on ice.
It slipped, on the ice, I steered a bit left and the left side dutifully pulled me up the 14% grade until I was off the ice patch.
Several times on my dry loose steep gravel I’ve watched the AWD RAV 4 loose it if it stops while going up slow and steady
And have to back down and need a running start to try again.
Only my Bronco Sport BASE and the true 4x4 pick up trucks and a Nissan Path Finder can stop and easily restart while on this climb when things are dry and loose.
We have a Subaru, two Rav 4’s, Two AWD Ford Escapes !
And a few more so called AWD’s. Not a single one can do this.
