- Thread starter
- #1
Looking to see if anyone is able to 3D print and make front hood tie down hooks to fit the BS?
I try to discourage using a desktop 3D printer to make accessories to be used in the cab of a car or out in the elements. Some 3D printer filaments have a low glass transition temperature and will not fare well in a hot car. Some, like PLA should not be used outside as they are biodegradeable. Also, the FDM process involves constructing an object by extruding and adhering layers together, so those layers are a weak point on prints that can split and break under stress.Would abs plastic even be strong enough for this purpose?
I've seen a few photos of (big 6g) Broncos in the wild using those as forward-lower anchor-points for deflection wires, to protect the windshield somewhat from brush.I came across this in Ford patents. They are called “trail sights” as well as some calling them ties downs and Ford was thinking of integrating turn signals into them. I recommend using them for trail sights only, then no underlying structure is needed.
Otherwise you have some engineering to do cause if something comes loose and flies off backwards you are in a world of liability hate for anything hit behind you.
I had the same thought.Looking to see if anyone is able to 3D print and make front hood tie down hooks to fit the BS?
Carbon fiber infused PLA will handle this application...or there is always a way of making a mold from cheaper plastic and casting.I have a 3d printer. Definitely do not use PLA for that. It will warp and break in the heat. I haven’t personally printed with anything stronger so I can’t speak to using ABS. If you’re looking to experiment though the Ender Pro 3 is a very capable printer and quite inexpensive. You will need to do a bit of research on the application and settings. And then finding someone who can create that for you. Or you can check out thingiverse.com for possible options.
One suggestion.....make that look like a capital B instead. Might just need the lower right hand corner to be angled to do that.V1. Will make next one a little beefier and probably going to remove the "catch".
Any other suggestions?
How are these attached? I am still waiting on delivery of my BS so I don't have a reference on what is under the hood ?V1. Will make next one a little beefier and probably going to remove the "catch".
