Can anyone 3D print
o0260o
NJ/NYC
BroncoSport
Would abs plastic even be strong enough for this purpose?
PirateBrahm
Bucks County, PA
I try to discourage using a desktop 3D printer to make accessories to be used in the cab of a car or out in the elements. Some 3D printer filaments have a low glass transition temperature and will not fare well in a hot car. Some, like PLA should not be used outside as they are biodegradeable. Also, the FDM process involves constructing an object by extruding and adhering layers together, so those layers are a weak point on prints that can split and break under stress.
Which is more durable to sunlight/weather - PLA, ABS or PETG
moserp624
Paul
Suffolk VA
Ford Bronco Sport, Mazda CX-5
I agree with discouraging the desktop 3D printer material for final usage of this threads concept/request.
In the spirit of keeping this thought alive though, I'd suggest using a 3D printer for rapid prototyping and template/fit-up verification. That 3D printed model can then be used for a mold of higher durability material.
Interesting thought here. I can't conceptualize how it would look on the BS. Would be interesting to see.
tburner
Troy
DFW, TX
I partially agree with what's been said. But 3D printed parts, when using the appropriate material (which is the case for any form of manufacturing), can produce durable and reliable parts for use outdoors and in high heat environments.
ABS can be used in outdoor/hot applications, and is done so frequently in industry. However, it's much more UV resistant brother, ASA, would be more appropriate for outdoors stuff. Both have a glass transition temp of over 200°F.
FDM/FFF layer adhesion can definitely be a problem, but print orientation can largely solve it. For something like this, printing normal to the side profile would not only be the preferred orientation to avoid print bridging and overhangs but would also orient the layers to significantly reduce the risk of failure along layer lines by printing the inside corners in each layer instead of the corners being formed between layers.
My biggest concern is installation and application. If it's for purely aesthetic purposes, you could slap them on with some VHB tape and be good. If you're actually wanting to apply anything more than a light load to them, I wouldn't trust VHB tape. You may have to fasten them to the hood with screws or rivets. You'd also have to drill holes in the base of the part (and the hood, obviously), which would increase the potential for failure along layer lines. I'd be comfortable with light loads, but heavier loads would be ill advised.
That said, I wouldn't want to do it simply because matching the hood contour in the model would be a pain in the ass.
Rgill
Vegas
Las Vegas
2011 Toyota FJ Cruiser
I came across this in Ford patents. They are called “trail sights” as well as ties downs and Ford was thinking of integrating turn signals into them. So they serve multiple purposes on the Bronco (tie down and trail sight),
I recommend if you make them you use them for trail sights only, then no underlying structure is needed.
Otherwise you have some engineering to do cause if something comes loose and flies off backwards you are in a world of liability hate for anything hit behind you. Below shows how much underlying Ford put into them.
https://pdfpiw.uspto.gov/.piw?PageNum=0&docid=10759330&IDKey=AEEDAB448EC7 &HomeUrl=http://patft.uspto.gov/netahtml/PTO/patimg.htm
Here is another picture I found
Ford Bronco Sport Can anyone 3D print 798B8700-878D-4D7F-A7A9-7F5610C485B3
VirtualJMills
Jason
California, US
I came across this in Ford patents. They are called “trail sights” as well as some calling them ties downs and Ford was thinking of integrating turn signals into them. I recommend using them for trail sights only, then no underlying structure is needed.
I've seen a few photos of (big 6g) Broncos in the wild using those as forward-lower anchor-points for deflection wires, to protect the windshield somewhat from brush.
Idontknow
Will
MN
Cross trek and grand caravan
I have a 3d printer. Definitely do not use PLA for that. It will warp and break in the heat. I haven’t personally printed with anything stronger so I can’t speak to using ABS. If you’re looking to experiment though the Ender Pro 3 is a very capable printer and quite inexpensive. You will need to do a bit of research on the application and settings. And then finding someone who can create that for you. Or you can check out thingiverse.com for possible options.
DISCOLEG
Carbon fiber infused PLA will handle this application...or there is always a way of making a mold from cheaper plastic and casting.
I was searching for another 3D topic and stumbled on this one. I don't see a use for this but might be something to play around with.
DISCOLEG
This is going to be a little bit challenging as our hood obverhangs...
V1 to the printer...
DISCOLEG
V1. Will make next one a little beefier and probably going to remove the "catch".
Any other suggestions?
Ford Bronco Sport Can anyone 3D print IMG20220220142319
Ford Bronco Sport Can anyone 3D print IMG_20220220_142928
DISCOLEG
Any suggestions? Going 1th...
Jonnie T
Jonnie
Ontario
One suggestion.....make that look like a capital B instead. Might just need the lower right hand corner to be angled to do that.
blankobject
Jason
Georgia
Nissan Pathfinder
How are these attached? I am still waiting on delivery of my BS so I don't have a reference on what is under the hood ?
