Downside of driving in 4wd lock full time?
bgomez
New Jersey
I have a badlands, what is the downside of driving in 4wd lock full time?
While driving in normal, I notice there is significant torque steer when accelerating out of a turn. If the 4wd lock button is selected, the torque steer is minimized since more power is sent to the rear. Besides the mpg hit, is there a downside of always driving in normal mode with 4wd lock selected?
Sorry if this was asked already, I tried searching first.
dejones64
Dan
MN
Lancer, BS BB
Watch this video. I don't think it's advisable to run 4wd lock full time.
MaxVelocity
Montana
1970 Bronco
Note: Do not use the four-wheel drive lock, the rear differential lock or off-road selectable drive modes on dry, hard surfaced roads. Doing so can produce excessive noise, increase tire wear and may damage drive components. These features are only intended for consistently slippery or loose surfaces. Operating your vehicle outside of these conditions could subject the vehicle to excessive stress, which may result in damage not covered under your warranty.
The above is out of the owner's manual found here: Four Wheel Drive
Rgill
Vegas
Las Vegas
2011 Toyota FJ Cruiser
Owners manual says NO. Any problems caused by doing so are no covered by warranty. All 4x4s I have owned say same. You can damage car.
Ford Bronco Sport Downside of driving in 4wd lock full time? FDF1A1FF-1D83-4A50-BBA5-36BDF1A6E4BE
Bluebaru
Seems a little odd to me as I thought they were based on the unit out of the Focus RS but I guess it could be a down graded version. Got to go by the manual in any case, for warranty.
bgomez
New Jersey
Well I guess my question is answered then. Thanks everyone. I am assuming the best way to avoid torque steer would be sport mode.
AllTerrain
S
Ca
Broncosports have power to all four wheels when they take off from a stop. Even on the street even in normal mode and then the power transfers to both front wheels.
you can look on the Badlands Monitor and it will show you.
Starts to transfer the power from the back wheels to the front wheels as you're going like 35 miles an hour or so.
I concur, the owners manual says not to do it.
JerryC
Memphis TN
I'll try not to get too far into the weeds.
On an axle unless the tires are same rolling diameter there needs to be a way to slow the difference in distance traveled. You have the same situation when turning as the outside tire will travel more distance. The differential on the axle is what allows to happen, an unlocked differential that is. If the differential is locked then something has to give, traction loss or hardware.
The BS has a differential between the front and rear axles, locking this has the same effect as above. Now the front axle speed must be the same as the rear axle speed, if not then something has to give. Again, traction or hardware.
Driving with center differential locked on dry pavement is eventually going to damage the differential as it has no give. In the BS this is a clutch that did the locking and will wear out as it is the point that gives under stress.
I hope I have this correct and I expect and appreciate others who know better and will comment
If you have to accelerate out of a turn ease the pedal down and as it straightens out then push pedal further down if you want. Don't stomp it down and you won't get torque steer. The 2.0 don't need much gas pedal to get it going quick.
I am an ex SRT-4 driver for 11 years got tired of wrestling steering wheel just barely dodging curbs trees telephone poles ect.
Idontknow
Will
MN
Cross trek and grand caravan
The BS has a differential between the from and rear axles, locking this has the same effect as above. Now the front axle speed must be the same as the rear axle speed, if not then something has to give. Again, traction or hardware.
accurate
