16 vs 17 tire options
Reklussloth
Colton
2021 bronco sport
So correct me if im missing something ... but dropping down a 16 in rim according to this calculator would allow for 235 70s.. ? If thats the case it opens up a huge selection of tires.
endrMinr
'21 Bronco Sport
The 16in rims should fit fine with a similar offset (37.5 OEM, so 35-40). Ive been looking at 235/75r16s, these look so much more aggressive and meaty than OEM Falkens. OD on these would be just under 30, so a full inch greater than OEM but rubbing should be minimal to none. 235/70r16 would fit fine, same OD as the OEM Falkens
Maxwellian
Maxwell
Los Angeles
‘21 Bronco Sport
I was going to try the Toyo Open Country, but got a good deal on BFG KO2s in 235/70R16. Been very happy with them, pretty quiet, tons of grip, not too heavy.
ChefDank
Nick
New York
Have you posted a pic with the 16's? Would love to see how it looks. I'm looking to purchase another set of wheels dedicated for some aggressive tires for my "overlanding" trips
Maxwellian
Maxwell
Los Angeles
‘21 Bronco Sport
Bluebaru
I was just about to ask if anyone had tried 16" wheels yet, when I decided to do a search and found this thread. The Tire Rack shows several 16" wheels that fit. The Motegi MR143 CS6, looks good to me, at 16x7 +40 and 18 lbs. I'm still questioning what the largest tire diameter is that will fit a Badlands without modifying the pinch weld and fender liner and/or requiring a lift. I was also hoping to up the selection of good AT tire choices. The Motegi in combination with the 235/75/16 Cooper AT3 4S at 33 lbs and a 29.7" diameter, makes for a light (?) 51 lbs combination.
I will probably do a lift but don't want to have to do one and I certainly don't want to trim the pinch weld. If I decide to stay with 17's, I'd probably go with the Motegi MR136 and a 235/70/17 and that combo ups the tire diameter to 30" with a weight combo of 59 lbs. , I think.
Maxwellian
Maxwell
Los Angeles
‘21 Bronco Sport
Yeah, 50w panel on a hood vinyl. Keeps the battery topped up nicely.
