Spare Tire Foam Tray uses.
nch5013
Nicole
Gallipolis, OH
2021 KB Big Bend
D-Man
Bronco Sport, Honda S2000
I think I am just going to ditch the spare, and throw it on top of my Rhino Rack Platform when I go off roading...that way I get all the additional storage under the cargo floor. Best of both worlds! Maybe I will use my Ford Rewards points to get the non tow package cargo floor instead of fabricating something out of plywood.
Little Wild Boar
Did anyone who removed the foam take a picture? Thinking about building a drawer or sliding load floor over the spare tire area. Wondering if there’s anything good below the foam to attach to, or if I’d have to put holes through the side plastics/use the tie down points.
I built a drawer for my 2009 Edge .. and found a coupling nut the same thread as the spare tire hold down... Just attached to that... Super strong
DebiHammel
Debi
Salisbury, MD
18 Ford Edge
I removed the foam— it was just a couple clips on each side that pulled up pretty easily, no stray bolts. I painted the well with Rustoleum undercoating just to ease any rattles and well, make it look more intentional (I’m Area 51).
Ford Bronco Sport Spare Tire Foam Tray uses. 4EF076AE-07B0-4CA7-9D7D-DBAB640F3663
J.Wal
James
Memphis, TN
Great stuff in here. Commenting mostly to keep up with it!
J.Wal
James
Memphis, TN
Had to go out and do some work on mine. I needed my jumper pack last night for my mother in law but had taken it out for other stuff. That won’t happen again!
Ford Bronco Sport Spare Tire Foam Tray uses. 6AE4F7DA-A180-4C3F-84D8-E77E71E5833F
Ford Bronco Sport Spare Tire Foam Tray uses. E0FED5CB-6E0D-4448-901C-B2DC78C437E0
SeaJay
Georgia
2023 OBX Sport, Area 51, Hitch, Assist++
And will you have rattling now?
I would wrap things in towels if I do this. If and when I need many of the things I would put back there a towel to kneel on or wipe my hands on is often needed too!
I flipped my 225 spare and found a suitable bolt to hold it down. I cut up a foam gym floor tile to fit into the spare, and there's room for a complete socket set, and a few other things. All the foam is out of mine, and I store a shortened Hi-Lift jack, Lift-Mate, jumper cables, axe, tow strap, poncho, large Cresent wrench, and a few other things.
Roadeo Girl
Ellen
Tustin CA
2024 BS
Ford Bronco Sport Spare Tire Foam Tray uses. IMG_9429
Ford Bronco Sport Spare Tire Foam Tray uses. IMG_9428
CasaMarPe
2024 Bronco SPORT
Great thread. Mine is a badlands trim with tow package so the cargo floor sits in the higher of the two positions, which helps. I was able to remove only the driver side foam and get a lot of usable storage for my overlanding/recovery gear. As of now, I have the following under there:
Viair 88P portable air compressor
30 ft kinetic recover rope
30 ft tow strap
Soft shackles
Folding shovel
Air down kit
Stakes for Yakima awning
6 ton bottle jack
Ford Bronco Sport Spare Tire Foam Tray uses. 0608210459b_HDR
What is the max height on the bottle jack? Had a flat at work and the slopped lot almost crumpled the scissor jack. Also looking for a full size spare. 24BB.
