- Thread starter
- #1
The BS Big Bend is currently using synthetic blend (not sure if the other trims are the same). Is there a benefit to switching over to full synthetic? What do you guys plan on doing?
And with a good FULL synthetic anything under 15,000 miles will be just as good. With far better heat transfer and more oil where it needs to be at start up...The Motorcraft synthetic blend is very good oil , according to oil analysis. The oil itself is made by Conoco Phillips. Anything under 7500 miles per oil change would be fine w it.
Was that a true synthentic or a hydro cracked dino base oil?A study, 15 years ago.
Two vehicles same V-6 same car same use. Full time courior. Several hundred miles a daycity and hiway
One on regular oil on on synthetic.
At 4,000 miles the additive package was used up in the dinosaur oil there by marking the end of the roach oils service life.
The additive package in the Full synthetic oil did not deplete until 16,000 miles.
There is so much data out there on this subject.
I run full synthetic and change at 10,000 miles.
That additive package is the anti corrosion, scrubbers, carbon encapsulated that let the oil itself do the one single job it's suppose to do above all else and that's heat transfer.
I don't remember, think it was Mobil 1Was that a true synthentic or a hydro cracked dino base oil?
Not to really school you so much but to add more to your knowledge. Just like you were talking about the synthetic blend being used because it's cheap and sounds good 'Synthetic' oil takes the same kind of hostages with IT'S marketing as well. There was a court case in 1997 ( Castrol vs Mobil ) it came down to what is a synthetic oil. Synthetic oil sold today have base stocks, these base stocks are the base oil the final product is largely based on with the only exceptions being the additive packages and such. These oils consist of Groups I,II,III all of which are Roach/Dino oil with III being the most popular in all the brands of "FULL SYNTHETIC", and very few are type IV and V ( THE ACTUAL ( man made) SYNTHETIC base) . Most oils marketed as synthetic in the USA are Dino oil that is refined and hydrocracked in a lab which makes the oils molecules uniform; with only a fraction of synthetics being a man made group IV,V synthetic that are man engineered that way from the get go. All of them work great in tests, the Group IV and V generally -but not always- test better. That all being said, Castrol used hydrocracked dino oil, Mobil used group IV actual synthetic base. Mobil got mad that castrol was marketing their refined Dino oil as a "synthetic". Mobil was marketing their oil as synthetic as well. Castol won, and now only in the USA do we have the majority of Full synthetic oils that are really mostly dino oil and some synthetic, synthetics.I don't remember, think it was Mobil 1
Never heard of hydro c dino..
School me if you have the time![]()
@Timsvtgen1 thanks for all of the detailed info. My wife’s Sport will only be seeing about 6k miles a year, probably considered “rough service” maintenance wise so I’ll be looking at 2 oil changes a year. In this instance, what’s your preference on full synthetic vs blend?
[/QUOTE
If it were anything other than rough service or if the rough service was just dusty road driving, I would go with syn blend and not look back. But if your rough service includes long idling times, and any towing or taxing the engine ( lots of high heat cycles) or primarily city driving I would def go with the benefits of a full syn .@Timsvtgen1 thanks for all of the detailed info. My wife’s Sport will only be seeing about 6k miles a year, probably considered “rough service” maintenance wise so I’ll be looking at 2 oil changes a year. In this instance, what’s your preference on full synthetic vs blend?
Yeah, that first oil change is a little cringy sometimes with all that metal flake.I have always switched my cars to full synthetic after the first couple of break-in oil changes. I use the synthetic blend on the first change because it's a little cheaper and I change it quicker. On all my new cars, the first oil change usually 500-1000 miles (change oil and filter), then again at 3k miles (change oil and filter). at 6k I change the oil and filter, but switch it over to full synthetic. I always use Motorcraft filters. I have been using this method since the 90s and have never had any engine issues. I can open my oil cap and look in the engine and they are as clean today as when I purchased them. Might be a little excessive to some, but it has worked for me and I'll stick to it. I change oil at 10k intervals in my commuter car and around 8k ish on the other cars. Knock on wood I have had good luck with this process and these intervals.
