Your Falken was the at3w, I had the newer non-factory AT4WThat’s odd, mine fit without any issues. See my post earlier.
I didn’t realize there was that much difference in diameter.Your Falken was the at3w, I had the newer non-factory AT4W
Weren’t the factory Falken 235s 11/32” when new? Even if not there was enough of a difference as to not fit without letting out air or pushing down hard then probably couldn’t easily remove (for the AT4Ws 235)I didn’t realize there was that much difference in diameter.
edit: according to the specifications, they should be the same diameter so I’m back to being confused!
The attached spec is for the OEM tire (FO) at the end. The outer diameter is correct. At least in my 22 Badlands, I could put a slightly larger tire in as there is some extra space even with the Falken 235/65-17. So, maybe the steel rim is the issue as it is narrower.Weren’t the factory Falken 235s 11/32” when new? Even if not there was enough of a difference as to not fit without letting out air or pushing down hard then probably couldn’t easily remove (for the AT4Ws 235)
Your pic should the spare with a badlands rim and I mounted on the factory spare rim, just another difference that shouldn’t matter
I’ve used EBay quite a bit over the past 15 years or so and have never had any issues. Now in full transparency, I’ve never bought a car or motorcycle off of it, normally just parts.I might have to wait on this. I've been checking Craigslist and can't find an OEM 1st gen Big Bend wheel. eBay is $200-260 shipped... a bit out of my price range for my needs and the risks involved with eBay.
Maybe on my next set of tires!
Yeah I've used them too, usually for smaller things. It might turn out ok but I'd hate to pay $250 and get a damaged rim, then have to deal with all that. And then maybe never even need to use the full size spare.I’ve used EBay quite a bit over the past 15 years or so and have never had any issues. Now in full transparency, I’ve never bought a car or motorcycle off of it, normally just parts.
I get it. I normally look for free shipping and returns allowed. I did see some for 192, but that’s still a lot if you are not planning on using it in your normal tire rotation. I also got mine immediately in 2022 so more than likely a take off and not from a wrecked vehicle.Yeah I've used them too, usually for smaller things. It might turn out ok but I'd hate to pay $250 and get a damaged rim, then have to deal with all that. And then maybe never even need to use the full size spare.
good to know the 245/65/17. Is the tire fully inflated and it fits fine but snug?I have a 245/65/17 in the back of mine. It's snug though so i only use the nut and bolt to hold my jack. Spare wheel and tie don't rattle at all.
Be careful. That's not my experience. While I did get the 246/65/17 to fit in there, I had to air it down to like 10 psi to get it to drop all the way down in the well and allow the cargo cover to fit properly.good to know the 245/65/17. Is the tire fully inflated and it fits fine but snug?
