Jonk
BC Canada
2021 Badlands
So here's a very specific fringe case for a simple foglight bracket...
Took part in the Thunderbird TSD Rally this year in BC - about 600 miles of navigating backroads in snow, ice, and mud. I needed some solid supplemental lighting for fog and snow conditions and had a pair of good old reliable Hella 500s sitting around. Compared to car headlights from the 90's the Bronco's headlights are incredible, but having an additional set of yellow spotties made a huge difference when the heavy fog rolled in.
There are lots of good nudgebar options already out there, but I only needed a temporary solution.
The Badlands conveniently has easily accessible tow hook bolts, so I did some quick modelling in Fusion 360, test-printed prototypes, and then had a pair cut and bent by SendCutSend for about $80 (awesome service, by the way). I went with 5mm chromoly and these things are rock solid. They bolt on and off in just a few minutes.
I know it’s a pretty niche application, but if anyone’s interested in the files I’m happy to share.
Update:
Here are the two .STEP files (one for each side) that can be dropped into SendCutSend and a Fusion360 file if you want to tweak anything.
https://drive.google.com/drive/folders/1rxJ_UzERKjZZmcYPTWnJQrcRP2otzFDc?usp=sharing
(There are a bunch of discount codes floating around out there for the service.)
Ford Bronco Sport DIY Foglights Brackets for Bronco Sport Badlands IMG_4482
Ford Bronco Sport DIY Foglights Brackets for Bronco Sport Badlands IMG_4481
Ford Bronco Sport DIY Foglights Brackets for Bronco Sport Badlands IMG_4538
Ford Bronco Sport DIY Foglights Brackets for Bronco Sport Badlands IMG_4545
Ford Bronco Sport DIY Foglights Brackets for Bronco Sport Badlands IMG_4744
Ford Bronco Sport DIY Foglights Brackets for Bronco Sport Badlands IMG_4770
Bach
2021 Bronco Sport Badlands, 2013 Ford Focus ST
These are great! I would love to have some fabbed up.
2025 Badlands Sasquatch
SCS is awesome. A few channels I watch (in particular, Superfast Matt) use them extensively, and the work they do is absolutely first-rate.
Jonk
Jonk
BC Canada
2021 Badlands
Haha Superfast Matt is where I learnt about SendCutSend. I uploaded the files, got an immediate quote and had them in my hands in Canada 3 days later. Amazing.
They even had an option for powder coating for $10/pc.
What's really cool is you can import their material profiles into Fusion 360 so when you model the bends you can get the correct radius for whatever steel/aluminum you're using.
Jonk
Jonk
BC Canada
2021 Badlands
Bach
Thank you so much for sharing. You are the best!
Bach
Granger Ford
Gold Sponsor
Zach
Granger Iowa
www.grangerford.com
Update:
Looks awesome! Perfect and ready for the off-road adventures!
