Changed Brakes, Now I have a plethora of warning lights
KingofMandalore
Dan
North Ridgeville, Ohio
Good morning all,
So I changed my brakes over the last few days and when I started it, it gave me a bunch of warnings, including "Hill start assist not available," "collision assist not available," "check brakes," a bunch of stuff.
To take you through what I did start to finish to see what I messed up, I took the car into the shop on Saturday to have the brake fluid changed. Took them about an hour, everything was working well after, drove home fine.
On Sunday I did the rear brakes. I put the car into Electronic Parking Brake maintenance mode, it confirmed it was on. I started in the rear: loosened the lug nuts, jacked the wheels up, removed the lug nuts, took the wheel off. I unplugged the power cord running to the motor on the caliper so i could move it more freely. Then I loosened the caliper bracket bolts and removed the caliper and bracket from the wheel assembly. I hung the caliper up by a hook. I removed the rotor. I changed the rubber boots in the caliper bracket. I thoroughly greased the inside of the boots and the caliper guide pins. Greased the pad arms and backs. In order to retract the piston, I used two tools: the First one was a pusher tool, almost like a clamp, except made for brakes. I put an old pad in, and turned it until it stopped turning. I then tried to put the brakes back on and get them around the rotor, but there was not enough clearance. So then I hunted down my tool to rotate the piston with the two little notches. I rotated clockwise until this piston did not turn anymore. I put the pads back into the bracket, was able to get it around the rotor this time. Put everything back together, plugged the electrical connector back in, and then put the wheels, etc. Back on. I did this to both sides.
Last night I did the front brakes. Same process, jacked up, disassembled, etc. When it came time to take the rotors off, they were more or less glued on there and I couldn't get them past the hub flange. So I pulled the neutral release cord in the cabin and rotated the axle so I could beat the rotor off with a mallet. Got it off, did the same process as the back (changing rubber boots, greasing pins, greasing pads, compressing pistons, etc.). I made sure the little tabs on the inside pad were pushed and seated all the way into the piston's circle. Then I put everything back together.
I got in the cabin, i made sure the parking jawl release switch was back in (I put this back into park each time after getting the rotor off each front side). I then got it out of parking brake maintenance mode. The parking brake motors worked because I could hear them whirring and it would say "parking brake on, parking brake off" etc. However, I had that plethora of lights I mentioned. I drove the car to break in the brakes, I assumed the lights would go away. I broke the brakes in, but once I got back the lights were still on. Another source said try disconnecting the negative battery terminal to reset it. I did that, but the lights were still there even with the battery disconnected for like 3 mins...
Both the rear brake electric connectors were plugged back in. The only thing I can think is that perhaps I wasn't supposed to rotate the pistons in the back all the way in when I was turning them clockwise by the notches? I also noticed that if I would pump the brakes once the car was off, it did NOT firm up like it's supposed to... I didn't do anything with the brake fluid, the level looked good when I check it, however I did notice a little moisture on the outside of the reservoir (even though the cap was on). I don't believe that was there when I got it back from the shop after the brake fluid change, but I also wasn't looking at it with a flashlight at night.
Can anyone advise me on what I may have done wrona if they've had this problem/are knowledgeable about these newer braking systems? Thank you very much in advance.
-Dan
Summers22
Jon
You didn't take the cap off the reservoir before compressing the caliper pistons? You may have excessive pressure in your brake lines now.
Summers22
Jon
I remove the reservoir lid, compress the piston on the caliper I'm working on, then once I am done with that entire caliper/rotor, install the cap, pump the brake pedal and repeat for each remaining caliper/rotor. I also use a self bleeder when finishing up a brake job, super easy and lets me know there is no air in the lines.
KingofMandalore
KingofMandalore
Dan
I did not, no. I had read somewhere that the reservoir has a rubber diaphragm designed to flex and release the pressure without damaging the system, so I left the cap on.
I'll have to try bleeding them when I get home tonight.
FunSizeBroncoJake
Jake
Bountiful, UT
2024 Ford Bronco
I didn't replace brakes, but when I got my lift kit put on the wiring harness for that systems got stretched and damaged causing all the same alarms. I ended up having to get a new harness installed. hope that helps
Summers22
Jon
Yeah I am not saying pressure is causing it, just a possibility. I would have removed the negative battery terminal first if I was going to unplug anything electrical.
Whpony96
Scott
Nampa, Idaho
Connect a Diagnostic Tool to it, (like a XTOOL D7 or similar) It will tell you what wheel sensor is damaged and not reading properly. It's either one (or more) of the 4 sensors, a plug connection or the harness itself.
KingofMandalore
KingofMandalore
Dan
Update for this: It turns out that when I compressed the pistons to put the new pads in, it ended up putting air into the brake system... This upset the computer and is why it was throwing all the codes it was and turned off all the systems it did. I asked the tech if I should've just waited to get it flushed until after I did the brake change, he said it really doesn't matter either way. They had to do a whole second flush to clear the air out, said it would be quicker than bleeding it and cheaper. I kinda feel dumb about it but it is what it is. My car's back on the road again. I did find an oil leak when changing the oil right before all this too, they said the turbo is seeping oil (normal condition for the 2.0 apparently?). They said they can't do anything about it before it turns into a full blown leak, so I'll just have to keep an eye on it. I did some towing through the mountains in PA between the last oil change and now, so maybe that worked it enough to make it spit some oil out... Anyway, I appreciate all your guy's help. Thank you for everything.
First I’ve seen anyone report turbo seeping oil is normal for Bronco Sport 2L engines
And have seen no SSMs, TSBs etc from Ford on that topic
Thanks for the update. I don't need brakes yet, but I'll pull this thread up when I do.
It always cracked me up how much brake jobs cost. The old drum brakes were a pain with all of the springs, but modern disc brakes were much easier. Sounds like they've made it harder than it used to be.
Just out of curiosity, how much did it cost to have the brake fluid flushed?
Interesting info about the brake lines getting getting air in them from compressing the pistons into the calipers.
I've done hundreds of brake jobs and have not had the brake system get air in it as long as the brake master cylinder fluid is kept at a decent level, and or if using the bleeders they are used correctly and all the brake components are in serviceable condition.
On a side note, I also have a Badlands, I'll have to check around the turbo for possible oil leaks. As Dude mentioned, I also have not heard of that being an issue.
kshaw
Kent
Gaithersburg, MD
I think that Ford transitioned to a different way to compress the brake calipers that requires a special tool that turns the caliper as it compresses. My old Miata and my 2013 Escape had the same setup. That could explain your problem with poor clearance. Did you have the swollen nuts problem when you were removing the wheel?
2025 Badlands Sasquatch
Don’t you think that’s kind of a personal question? ;)
Caro
Missouri
I’m having a similar issue. Do you happen to know the part number for the wire harness you had to get replaced?
