2025 bumper mount rally lights with custom bracket
The_Jimmer
Georgia
2025 Badlands Sasquatch / Desert Sand
Had a custom light bracket made by a local shop mounting directly to the existing bronco bolts. Had them put channel grooves in the top to mount thru so lights can be adjusted left and right as preferred. Used silicone gasket behind the mount to preserve the metal on the bumper. Can confirm that the exposed green wire just inside the front left fender well is a hot wire to toggle switch #2. Just connect the lights hot wire there and ground the other.​
Ford Bronco Sport 2025 bumper mount rally lights with custom bracket 20251011_093717
Ford Bronco Sport 2025 bumper mount rally lights with custom bracket 20251011_093712
Ford Bronco Sport 2025 bumper mount rally lights with custom bracket 20251011_091252
Ford Bronco Sport 2025 bumper mount rally lights with custom bracket 20251011_091050
Ford Bronco Sport 2025 bumper mount rally lights with custom bracket 20251011_091047
Very nice, easily reversible approach. If your fab shop has dimensions or drawings, it’d be nice for those wanting to replicate it.
The_Jimmer
The_Jimmer
Georgia
@The_Jimmer which auxbeam part # are those lights?
https://www.amazon.com/Auxbeam-Lights-Offroad-Driving-Wrangler/dp/B08N68P68G?pd_rd_w=8hpVV&content-id=amzn1.sym.4af096b2-fb5d-43d2-a23c-ac48118349a2&pf_rd_p=4af096b2-fb5d-43d2-a23c-ac48118349a2&pf_rd_r=MHXYT042CCJ6KJ1VQR6N&pd_rd_wg=M5y5A&pd_rd_r=348d4f8c-f01d-42a1-9352-4edb5e5b8cd3&pd_rd_i=B08N68P68G&ref_=pd_basp_d_rpt_ba_s_1_cp_t&th=1
These lights come with a prewired switch in the harness. Rather than cut it out of the harness I left it in place and leave the harness switch in the "on" position zip wired in a neat bundle right inside the left fender well. When the power is off there is no juice running to it so no worries on battery drain. If you ever decide to take it out you still have an intake harness to sell or use elsewhere. There is a small opening just beside the left headlight you can run your wires through easily.
The_Jimmer
The_Jimmer
Georgia
I can take some measurements, but I'll see if he can get me the CAD for it.
