- Thread starter
- #1
I appreciate the features in the vehicle, but I don’t like the lane keeping. Every time I turn on cruise control, the lane keeping also turn on. I haven’t found a way around that. Anyone know? 2025 BS Big Bend
Are you referring to 2025 models?There is a PID to change the default behavior from active lane assist to warning only. Buy the FORScan $20 license and the recommended dongle if you don’t like the default behavior. Keep in mind that insurance companies and lawyers will be able to retrieve this information and use it if you were to bring a lawsuit or were sued by a victim.
OBDLink EX FORScan OBD Adapter https://www.amazon.com/dp/B081VQVD3F
You can change the following distance for the adaptive cruise control, but I don't believe you can change the sensitivity of the lane centering feature--it's either on or off. If you turn off lane centering using the button on your steering wheel it says off even if shut the engine down and restart.I set the cruise control to regular and the lane control to low alert.
