Does anyone have a tutorial video or photos for the aux switch wire locations for 2025 Bronco Sport
Tickover
Benjamin
Meridian, Idaho
2021 Ford Bronco Sport 2025 Ford Bronco Sport Badlands Sasquatch
Dude, you might check out Rough Country also for brackets. Rough Country also makes a license plate bracket for small light bars. This might work for underneath your license plate or just bolt in on.
I was just curious … I have a 2022 badlands but maybe a ā€˜25 or a ā€˜26 in the future. Mine doesn’t even have the front license plate bolts (don’t need a front plate here so didn’t ask for that when I placed my order)
xtinction
Rich
2025 Bronco Sport Big Bend w/Black Diamond Package
Keep in mind, I have only owned my bronco for a few days. Just saw this when you started talking about the attachment points. I am going to use this for a light bar. Thanks for pointing this out.
Ford Bronco Sport Does anyone have a tutorial video or photos for the aux switch wire locations for 2025 Bronco Sport IMG_5034
Right but I was not discussing that specific Accessary Ready on the A pillar
I referred to the Ford "Accessory Ready" points which are bolt locations making it easy to bolt up items
Located around the vehicle on some 2025 Bronco Sport models and packages so don’t know if these bolt locations are on yours
The pic I posted should show some of those bolt locations on the front bumper and more around the vehicle maybe if applicable to yours
Do you want to post a clear pic of your front bumper and rear bumper?
Tickover
Benjamin
Meridian, Idaho
I see that, I checked mine out and there it is on both sides. I'm getting a rack on mine next week so not sure I can use those accessory ready spots. I wish Ford had the new accessories first, hope they don't drag them out.
There is a PDF posted on the forum which is for the accessory ready on the A pillar for ā€˜21-ā€˜24s (for running wiring down the channel), might be similar for the 2025s
I can locate that PDF link if you want. It’s quite involved to use it as the PDF shows
xtinction
Rich
Yeah, if it is not too much trouble, I would love to see that PDF. Thanks!
xtinction
Rich
Actually, I just found it. IT IS CRAZY! You have to disassemble half the car to get to it. That is NUTS. I do not consider that "Accessory ready"!
Perhaps easier on 2025s !! ??
xtinction
Rich
Yeah, info on the 25's is still a little thin. Been looking all over online. I may have to tinker a bit. Just don't want to break anything.
Steamboatsig
Conrad
Pahrump, Nevada
After days of searching and searching, I still cannot find the wires for the Auxiliary Switches (2025 Big Bend w/ Black Diamond). Do I need to cut the tape that is wrapping the wiring harness? I looked in the engine fusebox, in the engine bay, in the wheel well. Still can't find it.
Not one pic of the wires on the internet. The wiring diagram that is provided in the owners manual is useless. Does anyone have a pic of the wiring location? Specifically, AUX 3 switch.
Not a pic but have you seen the info in this post?
https://www.broncosportforum.com/forum/threads/bl-sasquatch-aux-switches-wiring-guide.13923/post-238127
