Does anyone have a tutorial video or photos for the aux switch wire locations for 2025 Bronco Sport
xtinction
Rich
2025 Bronco Sport Big Bend w/Black Diamond Package
Tickover
Benjamin
Meridian, Idaho
2021 Ford Bronco Sport 2025 Ford Bronco Sport Badlands Sasquatch
I am doing the exact same thing, going to add some ditch lights first. Before you start, get some trim tools as you are going to need to pop the fender liners to get to the wires on either side.
xtinction
Rich
Yeah, I have some. Funny, I was planning on adding the ditch lights too!
I would just like pics or video before I start so that I know exactly what to look for a where. If Ford gave pics instead of the drawings, it may be more clear.
If you could share pics or videos, I am sure that it would help a lot of people. Thanks!
Tickover
Benjamin
Meridian, Idaho
I can't start the project for two to three weeks. I need the blessing from the ditch light manufacture because I plan to change the wiring a little. I wish the auxiliary switches were rated more than 10 amps. I want to save the 30 amp switch for something else down the road.
Tickover
Benjamin
Meridian, Idaho
Yes, I plan to use one of the 10amp fused auxiliary switches to run a relay.
xtinction
Rich
Can you share which lights you are going with a wiring diagram that you are planning on using. Would love to see. I am going cheap off amazon. I plan on changing wiring as well. Basically removing their switch and wiring it into the Aux switch with the provided relay. I am not starting right away either. Would be good to swap notes here so others can see as well.
Tickover
Benjamin
Meridian, Idaho
I am using a pair of KC Flex ERA3 lights with the added amber lenses. It snows here in Idaho so the amber lenses help with reflections. A little pricey but don't have to worry too much about moisture getting into the light. I worry about that with the less expensive lights. I might install a light bar also, have not decided yet.
Yes, probably a good idea to document the install for other forum members.
xtinction
Rich
You weren't kidding when you said pricey!
I'm going cheap at first and I can always upgrade a bit if I want to. Florida here. Snow is not a worry for me. But water could be an issue. The lights that I am going with are cheap enough that if they get ruined after a summer, it would not be a big deal.
I will be looking forward to some of the install pics/videos. Thanks.
I'm going cheep at first and I can always upgrade a bit if I want to. Florida here. Snow is not a worry for me. But water could be an issue. The lights that I am going with are cheep enough that if they get ruined after a summer, it would not be a big deal.
How are you planning to mount your lights? Bolted on the front of your 2025?
Tickover
Benjamin
Meridian, Idaho
I have a cowl bracket for each side. You loosen the hood hinge and sandwich them in-between the hood and hinge. Just make sure you apply painters tape around the hinge on the hood in case the hood moves on you. The tape helps to reposition the hood to hinge.
If I mount a light bar it would go on top of the brush guard or below the license plate frame. Don't want to block any sensors.
xtinction
Rich
We don't have rough trails here in central Florida. More like dirt roads. And I am not planning on doing a ton of off road driving. Part of it is just aesthetics. See below for cheap screw down clamp. Was planning on mounting on hood closest to cabin. But now that I think of it, I may go light bar in that position and then ditch lights on top of brush guard like Tickover.
Here is amazon link:
https://www.amazon.com/dp/B0CS2ZYTF3/?coliid=I31KHWVCOZ54KN&colid=2XU48Y6V6PC1B&ref_=list_c_wl_lv_ov_lig_dp_it_im&th=1
See pic:
Without blocking any sensors:
1. Is it possible to remove the brush guard and mount lights in its place?
2. Or to use the mounting points for the front license plate in states that don’t require front license plates in order to mount a light bar?
Or maybe neither location are suitable places to mount lights or a light bar because lights would not be useful in that area?
Ford Bronco Sport Does anyone have a tutorial video or photos for the aux switch wire locations for 2025 Bronco Sport IMG_4596
xtinction
Rich
Couple of things. First off, great idea!
However....and this may be a stupid question....where are the license plate mounting holes? I do not see any on mine or in the pic? Are 2 of the large screws in middle for that and they just look like they hold the bumper on?
And second thing. You will be very close to the radar that the adaptive cruise control uses. That is the black box in center and above the bumper.
Correct .. I am specifically referring to not blocking any sensors including radar for adaptive cruise control
The front license plate would use the 2 or the 4 mounting locations in the middle of the pic I posted (located where you would expect a plate to go)
If you have that front bumper on your 2025 look around there and other locations for the Ford Accessory mounts … including in the interior behind the large center display on some 2025 Bronco Sport models and packages
I don’t have a 2025 so I don’t have a full list of the Ford "Accessory Ready" points.
Ford "Accessory Ready" points, often found on vehicles like the Bronco and 2025 Bronco Sport (certain models/packages), are pre-installed mounting points designed to simplify the installation of aftermarket accessories like lights, racks, and more, without requiring drilling or modifications.
Here's a breakdown of what you need to know about Ford Accessory Ready points:
What they are:
Pre-installed Mounting Points:
These are strategically placed locations on the vehicle's frame, roll bars, or other areas, designed to accept specific types of accessories.
Simplified Installation:
They allow for easy and secure mounting of accessories without the need for drilling or extensive modifications.
