Left Rear Running light not illuminated. I was told by Ford Service Rep. That I have to replace the entire unit, which I did still not lighting up, a
CancunBadlands
CancunBadlands
Cancun, MX
You must to.... there's not such a bulb replacement on that unit
#sorry
CancunBadlands
CancunBadlands
Cancun, MX
:shock: did you check the fuse box?!
Podaddy065
Dennis
Thunder Bay On
21 Bronco Sport
Fuses all appear to be good...I have a mechanic willing to do diagnostic on it but 2-3 weeks away
I don't know how strong your mechanical skills are, but, did you try putting a meter to the harness and seeing if the assembly is getting power?
Is the harness connector same left and right? Plug the working unit in and try it again. Don't install it, just plug it in and have someone hold it.
What fuse in which fuse box did you determine operates the lamp? Power is supplied by a state change in the BCM. So if the BCM fuse failed, neither lamp should operate. I agree probably not a fuse, but then either the splice point to the left lamp, or the lead to the ground point might be pinched or broken.
Is your sidemarker (rear) lamp on that side also nonfunctional? It could be a transistor failure in the BCM that just isn't turning on that supply. Weird but possible.
Ford Bronco Sport Left Rear Running light not illuminated. I was told by  Ford Service Rep. That I have to replace the entire unit, which I did still not lighting up, a Captur
Podaddy065
Dennis
Thunder Bay On
21 Bronco Sport
Thank you so much for your reply. I am digging deeper as we speak.
Tickover
Benjamin
Meridian, Idaho
2021 Ford Bronco Sport 2025 Ford Bronco Sport Badlands Sasquatch
Ouch! Please let us know the outcome.
PonyDriver43
Roger
NE FLA
Aren't LEDs wonderful??
Watching this thread for sure.
Ecom911
Ron
Manitoba, Canada
'22 Bronco Sport Big Bend - '06 F150 XL 5spd
I see you're in Thunder Bay, drop by Pinewood Ford, I'm sure they could find you an answer PDQ.
CancunBadlands
CancunBadlands
Cancun, MX
FORscan software could help!
CancunBadlands
CancunBadlands
Cancun, MX
FORScan is an OBD2 software scanner designed for Ford, Mazda, Lincoln, and Mercury vehicles. It's a free open-source program that allows users to interact with their vehicle's computer, read and clear diagnostic trouble codes (DTCs), and potentially change vehicle settings and parameters.
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
I know what it is, I've used it many times now. How would it help here in this situation?
OP's vehicle isn't throwing a cel
