- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,727
- Reaction score
- 13,166
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
Great, then you should have before/after testing data to show how that works. Can you share it?You're right that the turbo is a major restriction, but what happens after the turbine still matters. If you lower the pressure on the exhaust side of the turbo (by using a less restrictive exhaust), it actually helps the turbo spool more freely. That reduced backpressure creates a better pressure ratio across the turbine, which means the engine doesn’t have to work as hard to push exhaust gases out. Less work = more efficiency.
Even if boost pressure is limited by the PCM, the engine can reach target boost faster and operate more efficiently overall. That can lead to small but real gains in fuel economy, especially during steady-state cruising or moderate acceleration. Plenty of people have seen MPG bumps from exhaust upgrades, and this is why.
It’s not about changing boost levels—it’s about how easily the engine and turbo can breathe.
