Accessory Ready - Tray on Dash 2025
2025 Badlands Sasquatch
Surprised that there are no aftermarket options for this accessor tray.
I'm sure there will be soon enough, but it is kind of a limited market. I'd watch Bulletpoint and BuiltRight, they've been making mounts for the F-150 for a while now. Once my BL gets delivered (118 days since the order and still no production date!), I'll be taking measurements and start developing some different mounts & mini-racks using the "Accessory Ready" points.
Bernie
2025 Bronco Sport Big Bend with Black Diamond Off Road
I discovered that the USB-C port in the accessory tray of the 2025 bronco sport supplies power regardless of the engine on or off. Will drain the battery over time.
That would make sense to me for various devices (not to time out)
At least one other owner reported that same accessory USB-C port timed out and turned off so maybe it various with a setting or whatever IDK for the 2025s
And other owners reported that same accessory USB-C port was not suitable for many Dash Cams due to its limited current capability (one post is earlier #8 and related #9 but there are other threads on this topic)
TheX
Randy
Austin TX
I guess my point is that Ford should have a power source able to power any common accessory that you want to mount there, dash cam, portable GPS, etc. not just a phone.
^^this^^
hcrews1955
Hilton
Purlear, NC
I've looked and cannot find any info on the accessory ready M6-1.0 mounts in the dash tray. Are there kits or post you can put here.
Ford Bronco Sport Accessory Ready - Tray on Dash 2025 1741132876906-kz
Ford Bronco Sport Accessory Ready - Tray on Dash 2025 Screenshot 2025-03-04 185850
You can purchase from McMaster Carr a 6mm to 1/4 inch adapter then attach accessories such as bulletpoint mounting solutions.
Ford Bronco Sport Accessory Ready - Tray on Dash 2025 BS BL BPMS adapter 1
Ford Bronco Sport Accessory Ready - Tray on Dash 2025 BS BL BPMS adapter 2
rbow
2025 Ford Bronco Sport Big Bend, 2013 Ford F-150 XLT 5.0 4x4
I see this was posted back in March, any luck finding kits that work?
