Transmisión flush interval
DirtyLuke
Luke
Denver
21' BS BL, 18' Forester
I did mine at 39k after starting to see posts about transmission failures at 75-90k. My tech told me the fluid was pretty well spent already. The topic has been beat to death a few times now... But the 100k trans fluid interval that Ford advertises is a joke.
It's not 100K, it's 150K under normal ops, with 30K inspections, and 30K for severe duty. All this is covered in the owner's manual.
DesertRat19
Will
Phoenix
I’m almost at 30k miles. Going to do an oil change soon. I’ve done a few thousand miles of off roading and with the Phoenix gear coming up, I’ll ask them what they recommend and charge.
I’ll check out the links provided. Given costs of car maintenance I’m getting more into doing things myself. If it’s a drain and refill, sounds like I could do that.
Eddie McAloney
Eddie
Chatham Ontario
Bronco Sport 2021
oh and your in the US so that's probably like 250 to 300 here.. I know in my truck they want 900 bucks to drop the pan, flush and change the filter.. all they are doing is draining a bit and re-topping it off, but it is a pain to do from what the mechanic was telling me.
anyone from Canada have a ford price quote for the trans drain and fill?
From my Tilbury ON dealer on March 25 2025: "The transmission fluid change cost is about $350.00+taxes. (~ usd 244.+). The transmission fluid change is recommended at 100,000 km (~ 62,500 miles); spark plugs are recommended at 160,000kms (100,000 miles)".
MedTech
Treavor
Fullerton, CA
2021 Bronco Sport, 1999 C5 Corvette
Next time ask for a drain as pointed out earlier: “Flushing the 8F35 transmission is not recommended. Do a drain and fill or back to back drain and fill.”
From my understanding, the dealerships only do a flush, not a drain and fill. I had mine done at 35k and they charged me $280 and man the shifts are much smoother. I am not a big fan of flushing transmissions at all but would be curious to know where it says that a flush is not recommended for this transmission especially considering the dealerships are performing flushes. Either way, next I will do my own service now that I have nice scan tool and can read the transmission temps to be able to perform the service.
oharajoynr
So you’re saying the dealership did a flush with the existing dirty fluid and never drained and filled it with clean fluid? If they did actually flush it, where did they connect the flushing machine?
chipearly
chipearly
Chip
Wytheville, Va
2022 Bronco Sport Big Bend
I know on mine they drained it, filled and flushed with new oil, then drained it again and refilled. On my bill they listed 16qts of fluid.
oharajoynr
That makes sense, I did 2 drains and refills at 35k. The original factory fluid was black, and after the first drain and fill, taking it for a drive, the fluid was clear purple. After the second drain and fill the fluid was bright red. Yeah, it’s a lot of fluid expense, but worth the effort. I’ll do the same thing every 30k miles.
Stircrazy
BC, Canada
weird here in BC, the service schedule says 50000km for trans drain and fill. they can do it every 25000km if they want it is included in my service plan, but I was just wondering how much the normal charge is in Canada. the more things I get done the more I am liking this service plan, I thought it was expensive at first but in the long run it is going to save me money.
MedTech
Treavor
Fullerton, CA
Have no idea about their process or where they connect the equipment, all I know is they state it as a flush, not a simple drain/fill. I have never been a fan of transmission flushes, moving forward I will do a simple drain and fill.
Stircrazy
BC, Canada
I don't think flushes are bad if they are done right. A trans shop out where I am does their flushes by letting the trans oil pump do the work, when they have the pan off they hook tubes up to the trans pump inlet and the return to the pan and let my truck do the flush. I think it is the aftermarket power flushers that use much more pressure that can be a little sketchy. so for me it is how they do the flush. I will have to ask them how they do a ford bronco sport that has no serviceable filter.
Foghorn
Canada , East Coast
Had transmission fluid drain and fill at my Canadian dealer Sept 30, 2025.
4 L of fluid at $10.25 per and $130 labour ( 1 Hr ) plus env fees. and taxes.
No bill for new drain plug.(s) Reusable? I hope. .
Fog
Ksnau
SEAN
Phoenix
2022 bronco sport
So actually, I would recommend every thirty thousand and there's a guy on youtube thats a ford tech That makes a lot of videos it fordtechmakuloco or something and that's what he recommended. Because there's no filter to change on our eight speeds.Like there were in the old ones so that filter is there for life.So you want to keep that flute as clean as you can.
Also, there is a difference between a flush and a drain and fill our transmission holds I want to say like twelve quarts, but if you just drain it, you're only going to get about five quarts out of it but there's still going to be a bunch in the lines.In the cooler and the torque converter and stuff, and so that's where you get an actual flush where they flush the entire system, which is a process, now what you can do at home is you can do like three drain and fills, and then you want to run the car in between to cycle.The fluid and you can dilute it more and more me personally.I just did a drain and fill, and i'm going to do that every thirty thousand for now, as long as it looks clean if it starts looking dirtier, I'll probably do a real flush or at least do multiple drain and fills at once but again mine actually looked pretty clean.Still, I did mine at thirty seven thousand and we just did my friends at.I think he was at thirty six thousand and his was a little dirtier, but not bad at all still pretty new looking, which is what you want it like when you change it since you can't change the filter
TheX
Randy
Austin TX
I will be doing this every 25K miles. That's about 3 years worth of miles.
