Retired Plowman nube here
Larry
Merrimack , NH
2023 Bronco Sport 2013 F150
Just bought a '23 with 7k. We are impressed so far (1 week) Window sticker shows the following 2 functional adds "Refresh95 & Wiring prep- pack. This is not my first rodeo, read many window stickers in my 80+ years but ???????
Refresh95 is Ford Marketing for the interior Cabin Air Filter located behind the glove box. You can google Refresh95 and see Ford's writeup but near as I can tell you cannot purchase a bonified Refresh95 replacement Cabin Air Filter.
Wiring prep- pack is a term for the channel located on driver's side A-pillar. See this post for more info:
https://www.broncosportforum.com/forum/threads/wiring-prep-pack.7912/
As @Dude says, cabin air filter and accessory wiring. The issue with the wiring is there are not accessory switches like in the 25 or the full size Bronco that they run too. Most have found they don’t add much value in the case of the 21-24 Sport.
And there is no actual wiring just the channel for the wiring
There is a small section of wire that runs down to behind the light switch module. This does help a little (very little) but nothing like what is done on the full size. Not sure if this was improved upon with the 25’s and the accessory switch panel option.
Ford Bronco Sport Retired Plowman  nube here IMG_1268
Ford Bronco Sport Retired Plowman  nube here IMG_1267
Did not know that… thanks !!
It will be interesting to see what the 2025 Badlands does with the aux switches.
BSBB4Les
Les
Hello and welcome to the forum Retired Plow Man!
I just saw this posted on another thread. Very similar to the full size less two more switches and locations.
Interesting. I found no other info and ChatGPT currently only shows info from the posted link to the bronco nation article.
This was the first I saw of the details too. I knew about the switches but wasn’t sure of the implementation considering how poorly ours was implemented.
