- Thread starter
- #1
Intermittently while at idle there is no heat. Vents blow cold until you start driving again. Then heat returns. Also seemed to only work with recirc selected. Might be ok next leg of trip. Anyone else?
Have to think on that idea. Seems more like blend door issue or similar. Since recirculating has to be selectedprobably thermostat going bad and sticking.
could be yeah. could also be your water pump failing on the 1.5. did you check coolant level?Have to think on that idea. Seems more like blend door issue or similar. Since recirculating has to be selected
Will check. Just seeing if anyone else has experienced the same. Dealers like to blow stuff off. Quoting TSB or having some knowledge has helped in the past. I went round and round once because service manager(not at Ford dealer)said it wasn’t a know issue so problem didn’t exist. I said someone has to be first. Service writer found that there was an issue.could be yeah. could also be your water pump failing on the 1.5. did you check coolant level?
being a 23 take it back to dealership have them take a look. better than us just guessing.
Sometimes we guess better that the dealerships. ?could be yeah. could also be your water pump failing on the 1.5. did you check coolant level?
you're not wrongSometimes we guess better that the dealerships. ?
My Jeep Cherokee does the same thing. The heat won’t come on when I do remote start. But once I start it the heat comes through.Will check. Just seeing if anyone else has experienced the same. Dealers like to blow stuff off. Quoting TSB or having some knowledge has helped in the past. I went round and round once because service manager(not at Ford dealer)said it wasn’t a know issue so problem didn’t exist. I said someone has to be first. Service writer found that there was an issue.
So not the same thing. Entirely a different thingMy Jeep Cherokee does the same thing. The heat won’t come on when I do remote start. But once I start it the heat comes through.
OkSo not the same thing. Entirely a different thing
Water pump leakIntermittently while at idle there is no heat. Vents blow cold until you start driving again. Then heat returns. Also seemed to only work with recirc selected. Might be ok next leg of trip. Anyone else?
