Deleted member 12075
I had a LiFePo in my 2015 Dyna Low Rider, worked flawless for me up till the time I sold it in 19. Then again, my sled was probably newerNot sure that this is truly an "apples and oranges" comment from @Mwittke5857, more likely just a misunderstanding, as I think @MarkS was trying to show. The lithium-ion batteries do still function at low temperatures, just at a lower capacity (as has been stated and is well known by those who have an interest).
Your comment about the batteries shutting down at low temps is probably jumping to a conclusion. At higher temps the battery shutting down is safety related, as they would not want a fire/explosion caused by the heat. Which reminds of another reason I personally would steer clear of lithium-ion in my vehicle.
You did mention motorcycle batteries and I believe (the last time I looked was a few years ago) those are generally LiFePo, which is different from what we generally think of as lithium-ion. I did have one of these in a motorcycle about 5 years ago and it worked great, until it got below a certain voltage and then it would no longer charge. That was probably due to an older charging system on an older motorcycle but it still left me stranded in the end.
I agree with you that for the most part, AGM is probably the correct choice. I do think the thread title is a little misleading since AGM has been widely available for decades. We all know OEMs are not using them much and that probably comes down to cost, though some BSs came with them in the pandemic years at least.
