Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
You might want to check out the first post in this build thread.
i went back and looked at this thread since @OrangeJoe mentioned he used the same wheel and tire set up as you but didnt see where you listed wheel specs. instead of jumping back and forth through all your pages where multiple people posted pictures of their different set ups, i figured it was just easier to ask again for clarity.
looks like a 245/70/16 will fit with a 16x7 et30 but probably only practical with some lift
cprcubed
Parker, TX
See this post: Olive - Meanderthal’s BS BL | 2021+ Ford Bronco Sport Forum - Broncosportforum.com
Cheers!
I did point you to the first thread, because it has a link to the specific post related to the wheels/tires that does show all the information (Thanks @cprcubed for posting that specific link). I pointed you to the first post because you might find other information there that might prove useful. I would not ask anyone to read through 14 pages, which is why I created my build thread this way. It is easy to find my specific information by following links in the first post.
I've said it in this forum many times, and I think others have too, a lift does not affect the fit of the tires on the BS. You can have a 245/65/17 or 245/70/16 or 245/60/18 on the BS without a lift. The wheel offset does affect this some, as a lower offset will move the tire out, which will put it closer to the pinch weld at the back of the front wheel wells when the wheel is turned.
Quashish
Tomas
Sacramento
I did look through all 14, decent read. But yes on page 1 post #2 does not list the width of the wheel. Or anywhere else in this thread. Both links just take me to pages that list blank options for all kinds of different wheel models. As if I knew what I wanted to narrow search results.
Why I asked initially.
Just for clarity, the wheel width is listed in the image:
Ford Bronco Sport Olive - Meanderthal’s BS BL 1736372912281-zk
Well shit I totally didn't see that. Why couldn't you just say so for clarity? If we're being totally clear of course.
Just for you, I updated the text. The Discount Tire link still works and the 16" only comes in 7" width. It appears that 17" only come in 8" width.
