Smell coming from vents.
Ericnovitskiy
Connecticut
I’ve seen some people on here talking about this. There’s an exhaust like smell coming thru the vents when I have my AC on now. I changed the Cabin air filter, which was due for me to change. The smell is a bit less but it’s there. Does this possibly have a connection to the Cracked fuel injector CSP? If anyone else experienced this did you get it fixed?
21Broncosaurus
Ish
SoCal
21 Bronco Sport
Definitely a cracked catalytic converter. I had this same issue and got much worse over time. Make sure you take the tech on a ride along and make sure they can smell it because if it’s faint they won’t fix it and you’ll get your typical “couldn’t replicate” answer.
Hi there, Eric. Go ahead and send us a private message with your VIN and the name and location of your Ford dealer, and I’ll look into this concern regarding your AC.
Ericnovitskiy
Ericnovitskiy
Connecticut
What you said pretty much is what happened. They called and said the mechanic can’t find any leaks or problems. I said well then why is there a smell, there wasn’t a smell for the last 3 years. The rep said well if it continues drop it off again. No help as usual from my dealer.
I would take it to a muffler shop. I would think any of them would have a CO sniffer. Carbon monoxide will make you sleepy and give you a headache, right before it kills you.
kshirley47553
Kimberly
Georgia
Did you ever get this resolved? Currently on my fourth trip trying to figure this out.
Good afternoon! If you'd like additional assistance, feel free to send us a private message with your VIN and dealer info and we’ll look into this smell concern further. Thanks!
Charlie Horse
Steven
Denver
2021 Bronco
I will be visting my local Ford dealer with this same issue. I smell exhaust fumes in the cabin. It has gotten stronger to the point where I will nolonger drive it. I have been told that it may be several days before the cause can be found. I will inform them that it may be the catalytic converter. This is a 2021 BS Big Bend with 42,000 miles.
Hi there! If you'd like to, go ahead and send us a private message with your VIN and dealer info so we can assist with your exhaust smell concern. Thanks!
Hello
As requested herE is the VIN for 2021 Bronco Sport BL.
I would delete the posts containing your personal data (VIN) and send it in a private message. Click on the FMC avatar, then select "Send direct message."
Charlie Horse
Steven
Denver
2021 Bronco
Thank you Wiil do
