2024 BS Outer Banks Auto Dimming Mirror Seems Dark
Cactusjk
Jeff
Woodland Hills, CA
Have not seen many threads on this. Any others having this problem and if so is there a fix?
Cactusjk
Cactusjk
Jeff
Woodland Hills, CA
Will try that. Is the sensor supposed to be on the bottom or top of the back of the mirror?
Cactusjk
Cactusjk
Jeff
Woodland Hills, CA
Can someone send me a picture of the back of their auto dimming mirror so I can confirm if mine is upside down?
DWG
New Jersey
looking at the back of the mirror while standing in front of your Bronco Sport the sensor is at the bottom left corner of the back of the mirror.
Rawah652
Jen
El Paso, TX
2022 Ford Bronco Sport, 2004 Ford Thunderbird
My 2022 is a bit too light at times. Perhaps they attempted to fix the issue and overcompensated?
Take it in and see.
Cactusjk
Cactusjk
Jeff
Woodland Hills, CA
That is where mine is so the mirror is positioned right.
DWG
New Jersey
When you say the mirror seems dark do you mean in daylight or at night. The auto dim mirror is supposed to dim at night when there are headlights in the rear view mirror.
From the Owners manual (Page 92 of my 24 manual)
Automatic Dimming Mirror (If Equipped) Note: Do not block the sensors on the front
and back of the mirror. A rear center passenger or raised rear center head
restraint may also block light from reaching the sensor.
The mirror dims to reduce the effect of bright light from behind. It returns to
normal when the bright light from behind is no longer present or if you shift into
reverse (R).
Cactusjk
Cactusjk
Jeff
Woodland Hills, CA
reverse (R).
It is very dark in daylight. Haven’t had it out at night yet.
Mine can look very dark in daylight but I just reposition the rear review mirror slightly and the mirror looks normal
Maybe the fuse for the mirror blew? Sounds like a dealership issue to resolve?
Cactusjk
Cactusjk
Jeff
Woodland Hills, CA
Agree. Thanks for the help. I will have the dealer look at it.
@Cactusjk what was the solution to your issue with the rear view mirror being too dark in daylight?
thomasm23
Los Angeles Metro
You are adjusting the mirror incorrectly. There is a normal and dimmed area of the mirror.
Adjust the mirror by rocking it up or down to get the “normal” area in your view.
Cactusjk
Cactusjk
Jeff
Woodland Hills, CA
Can you elaborate? Might be what I need to do. Thanks.
