saw this the other day online, great spot for switch panelTnx for the update, I plan on routing around in there to see if and where I can mount aux switches
Next up, anyone know where I might find an A pillar gauge (triple 2 inch) pod?saw this the other day online, great spot for switch panel
I am just guessing but do you mean a pod to hold 3 2” gauges and mount to the A piller?Next up, anyone know where I might find an A pillar gauge (triple 2 inch) pod?
Yes sirI am just guessing but do you mean a pod to hold 3 2” gauges and mount to the A piller?
Similar to this
https://a.co/d/cXHWYaJ
Yes sir
Perhaps not this one in particular !!Yes sir
lol yep definitely not that one!!Perhaps not this one in particular !!
Excellent post! So good that it was on the first page of Google search results.It's similar to the console I replaced in a Ranger.
There are 2 pieces. There is a cover and then a part actually mounted to the roof under the headliner. The cover pulls off. You pull at the sunglass end with a trim tool. After the retainers pop, you have to pull it back to release the front tabs. There are electrical connections so only go as far as the harness allows until you unclip the electrical harnesses.
Here are the best pics I could grab, from the Ford Parts website. I know you grabbed a stock photo with the sunroof, but both parts are pretty similar.
Thanks Tim! I hope you're right about the 'rivets' being bump stops. I'll have to remove the console and find out.I'm not convinced from that other pic the upper piece is riveted. I think the two "rivets" mentioned are actually bump stops for the glasses holder. It could be there is a plastic push pin on the harness holding it, or screws in the recessed holes? Yeah, I would use a pair of trim tools to keep the first set unclipped while getting the others.
I haven't messed with my Sport's glasses holder/console. I did take out an A pillar and I was able to gently pull back the headliner over by the door openings. The sunvisor mounts and the handles are also doing a lot of work holding the headliner secure. That was my (now somewhat foolish) attempt to feed a wire back to the roof hole for an antenna. Maybe you can get enough access that way? Taking the whole headliner down is a pain. There are plastic posts and clips glued to the headliner and roof panel respectively. If you gently pull back the headliner above the rear hatch, you can see some of them about 1/3 in the window edges. Seems fragile IMO so I just put mine all back before something broke off or the liner crimped.
This document is referenced on a few threads posted here. I've looked at it a few times for part removal instructions.
https://www.fordracingparts.com/download/instructionsheets/IS_M-15200K-CXR_022321.PDF
You're correct -- the "rivets" are soft rubber bump stops for the eyeglasses holder.I'm not convinced from that other pic the upper piece is riveted. I think the two "rivets" mentioned are actually bump stops for the glasses holder. It could be there is a plastic push pin on the harness holding it, or screws in the recessed holes? Yeah, I would use a pair of trim tools to keep the first set unclipped while getting the others.
Now I need to figure out how the mice are getting in. I recall someone suggesting the cabin air exhaust vents.
No link … that image appears frequently on this Forum but I’ve never clicked to see what it is pointing toThanks Dude.
Did you mean to include a link?
