Charger Cubby OEM Ambient Light
Humper
Mick
Oklahoma
Hey guys, can anyone who has the charger cubby OEM ambient light take night Pic, looking to see how much light the OEM light puts out, I've search but can't find any night shots of that area.
Thank you.
Stircrazy
BC, Canada
Thank you.
there isn't any in the charger spot. from what I have seen its floors and door handles I was kind of disappointed, the wife's 2019 has way more including light up rings around the cup holders and such and she can change the colors.
Humper
Mick
Oklahoma
There was a light on the early models in that area, I have a 24 and there is still a slit in the tray where the light used to be, I believe it was one of the things Ford removed.
Mine did not come with lighted cup holders, but with the help of this forum i now have Explorer lighted cup holders.
Ford Bronco Sport Charger Cubby OEM Ambient Light 1000004912
I think every Sport has that lens installed. Even my Badlands has that much... but no LED module. I looked at putting one in once upon a time. It was easier to just get one that plugs into the USB or 12v. You can even get ringed or pass-thru ones so that you don't lose the plug if you use them all. This was the part I ordered, or tried to order. The local Ford dealer was... difficult about ordering the part. What I got was another lens and no LED, but the parts guy said everyone was curious about it and the bag had a hole. So maybe it was just a part monkey victim.
If you already added the cupholder, I bet you could splice that in too. Not a large draw amp speaking.
https://parts.ford.com/shop/en/us/electrical/wire-looms-and-connectors/wire-13293227-1?pdp=y
Humper
Mick
Oklahoma
Thanks, I already have the part and was planning on installing it this weekend, doing just what you said, splicing into the cup holders. I just wanted to know if it was worthwhile with how much light it it gave in the cubby area.
I won an auction on ebay for the whole charging tray, with lighted USB ports, 12v outlet, cubby light (with the LED) and wireless charger for $38.
I don't like that area being so dark.
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
could you share that part number? i wouldn't mind adding that feature if possible.
Jmuns
2022 Bronco Sport BL
Humper
Mick
Oklahoma
I don't have a part number, I just found one of these on e-bay, most I have seen do not come with the LED, I got lucky and found one with everything I needed you just have to keep searching ir buy one of the parts that Glamdring70 posted a couple of posts back.
https://www.ebay.com/itm/375440845011?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=24_bpnuatj-&sssrc=4429486&ssuid=XAeyscqJT0m&var=&widget_ver=artemis&media=COPY
Humper
Mick
Oklahoma
I've already been in there to add the cup holders/lights, mine had the standoffs in the plastic and the slit for the lens, but no lens or LED.
Stircrazy
BC, Canada
interesting, I was actually quite disappointed with eh "Ambiant lighting" when I turned it on at night. I don't mind the amount it outs out, it is a nice glow in the foot area and the door handles but like you the fact the cupholders and storage/charging tray were not lit up were disappointing as well as not being able to change the colors like every other ford ambient lighting setup I have seen.
Mrmike
Syracuse, New York 13219
You just pick up a Ford Escape cupholder and wire it into your front foot area light. Check this forum, there are several good threads to do this. The charging tray area can be lit by several different options. One plugs in the USB port, or one plugs in the round 12-volt port. Here again look through the forum to find the threads.
EARLSAYS
Earl
Houston
Which wires did you splice into for the illuminated cup holders?
Humper
Mick
Oklahoma
Spliced into the passenger side footwell lights, if I remember correctly the wires on the explorer cup holders are the same colors as the cup holders.
This forum has a great write up.
EARLSAYS
Earl
Houston
Mine lacks footwell lighting, the connector has three wires, positive, negative, and ?? whatever the third wire does.
Stircrazy
BC, Canada
should be a data line for dimming and color change.
